SanFranCyco
close
- Join DateSep 2009
- LocationSAN FRANCISCO
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car87 GTA
- EngineL98 5.7 24#inj,World hds,MSD,nosmog
- Transmission700R4 truck clutches,Trans go shift
- Axle/Gears10 bolt chevy 3.73 limited slip
- Liked:0 Times in 0 Posts
I have a 87 GTA with the WS6 suspension. when the car is on the freeway i get a pretty good wobble from the front end.also when braking it gets worse.any advice appreciated thanks.
Sounds like a front wheel bearing.
Former Sponsor
Quote:
Check the wheel bearing for play,worn bushings,worn motor mounts etc.Originally Posted by akmusclecar
Sounds like a front wheel bearing. JamesC
close
The car's 20+ years old. You may/will need a front end rebuild at some point. Beyond guessing, diagnosis is difficult.
JamesC
JamesC
SanFranCyco
close
- Join DateSep 2009
- Car87 GTA
Thanks for the replys. will check for worn parts.
SanFranCyco
close
- Join DateSep 2009
- Car87 GTA
The wheel bearing needed to be repacked.I did it yesterday and car drives great.
Oh yeah. i knew that it was a wheel bearing.
Re: Front end wobbles
It is so nice to see the original poster come back in and tell the conclusion of his/her dilemma.
You took advice, you went and checked things based on advise, and came back and reported what the culprit was and how you fixed it.
now anyone that searches 'wobble" can see this as a potential conclusion to there future puzzle.
thank you, I applaud you
Dean
Quote:
For TGO achieve sake-Originally Posted by SanFranCyco
The wheel bearing needed to be repacked.I did it yesterday and car drives great. It is so nice to see the original poster come back in and tell the conclusion of his/her dilemma.
Dean
