lower control arm relocation brackets
Old Oct 1, 2009 | 10:05 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
i have aftermarket non adjustable lower control arms..i love them... much better traction and just feels better than the stockers. i was wondering would lower control arm relocation brackets benefit me any... my car is stock height and i thought these brackets were only needed for lowered cars...... i dont want to kill my handling for straight line performance... do these brackets give u better handling and traction or what.... are they worth it.... thanks in advance...
Old Oct 1, 2009 | 10:16 PM
Stephen's Avatar
Car: 87 GTA
Re: lower control arm relocation brackets
Mainly for lowered car, but MAY improve traction on stock height vehicles, because of the differently resulting angle in the rear suspension geometry.
I have a set of Spohn weld-on ones, I'd trade for a set of the UMI bolt-on ones.
Old Oct 1, 2009 | 10:20 PM
88fastgta's Avatar
thats what i thought.... i dont think its really going to help much on a stock height car if i already have better control arms and panhard bar.... i think the torque arm and the relocation upgrade would be much better and help out alot more anyways than the brackets would... i dont plan on ever lowering the car because of my pipes and alstons frame connectors scraping as it is... i couldnt beleive what a lowered car would do to them...
Old Oct 2, 2009 | 08:57 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
a couple of things to consider... you have stock springs in your car...are they sagging? is it lowered becuase of that? if you want, measure from the ground to the fender lip front and rear and post the numbers. Also, with the car sitting level, are the control arms angled up somewhat? (up meaning the front of the arm higher) those are more determining factors as to whether or not you might benefit from lcarbs.
Old Oct 6, 2009 | 09:55 AM
BMR Sales's Avatar
Former Sponsor
Also take a peek under the car and see how your lower control arms are sitting (on a flat/level surface of course). Level with the ground or the rear slightly lower is ultimately where you want them. If the front mounting point of the control arm is sitting lower then the rear mount then the CAB would defiantly help.
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
