steering and spindle knuckle?
Old Nov 2, 2009 | 06:04 PM
antosh's Avatar
Car: 1991 camaro z28
Engine: 5.7 TPI L98
Axle/Gears: stock
stupid question but are they the same thing i am about to order a new one but both keep poping up and i dont want to get the wrong thing
Old Nov 2, 2009 | 06:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: steering and spindle knuckle?
what are you trying to buy? The spindle/knuckle is the large cast piece that the rotor, strut, brakes ect bolt to.
Why do you need new ones? they rarely go bad. If you need different ones, your best bet is a junkyard/ebay/classifieds. New OEM ones are retarded expensive
Old Nov 2, 2009 | 06:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I agree. The last ones that I purchased were $20 per at a bone yard.
JamesC
Old Nov 3, 2009 | 05:52 PM
antosh's Avatar
Engine: 5.7 TPI L98
Axle/Gears: stock
yea i just need a right one because it got bent when some one decided to hit the side of my car i took it to an alinment shop to see what needed to be done and they said over 600 for just the steering knuckle ball joints and idler arm so know i am trying to find a used one on the internet found all the other stuff for cheap just need the ball joint remover tool and the knuckle and it should be good as before
Old Nov 16, 2009 | 02:20 PM
z28m8's Avatar
Car: '91 camaro z28,imsa widebody
Engine: 383 ci l98,lt1 induction
Transmission: race built 700r4 , ratchet shifter
Axle/Gears: 342;1 detroit true trac diff
hi there, i need to get two spindles as im about to build a big brake/brembo conversion,,,, i need to know, apart from abs, 1le etc ,are they all the same if you fit them in pairs. im about to borrow some from an '85 car to put on to my'91. what you guys reckon????????????
Old Nov 16, 2009 | 02:30 PM
JamesC's Avatar
Bolt-up.
JamesC
Old Nov 17, 2009 | 01:31 PM
z28m8's Avatar
huh????????????????????????????????????????????? thats not the answer i was lookin for!?!?!?!?!?!?!?!?!?!?!
Old Nov 17, 2009 | 01:49 PM
JamesC's Avatar
Perhaps I've misunderstood your question. The 85 spindles will bolt up to your 91 with no problems (even the 1LE spindles are modified OE's).
JamesC
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
