Pitman arm / steering box question
I changed the steering box out and bolted everything back in place but my question is...when I tightened down the pitman arm, I could not get it to seat as close to the steering box as it originally was. It's about centered instead of fitting up real close to the steering box with about as many threads on top and below the retaining nut. Is this ok? I only had a breaker bar to tighten it back down, no impac wrench. Do I need to take it to a shop to get the pitman arm closer to the box itself? Hope all that made sense.
Mike
Mike
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Re: Pitman arm / steering box question
Did you get it on the splines correctly??????
Yeah it lined up fine. When I went to the parts store looking for a special tool that's supposed to be needed to put the pitman arm back on, I talk to a mechanic that told me I would not be able to get it all the way on with my own strenght, that I would need an impact to do it.
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
You're probably fine. You may now want to adjust the height of the idler arm so they're equal though.
Terrell351
06-13-2021 01:13 PM
backtothe80s
09-05-2015 12:39 AM
