FRONT END BOUNCE.
Old Nov 12, 2009 | 12:58 PM
DONNYBAKER's Avatar
FRONT END BOUNCE.
I WANT TO KNOW WHAT SPRINGS EVERYONE IS USING? I BOUGHT SPRINGS FROM THE PADDOCK PART#CS5662. I LOOKED THE SAME PART NUMBER ON SUMMIT AND THEY ARE RATED 748 IN/LBS. THE FRONT OF MY 89 CAMARO IS TIGHT, AND GOING DOWN A COUNTY ROAD ABOVE 65MPH IS NERVE RACKING. THE FRONT END BOUNCES AROUND. I HAVE BRAND NEW KYB AGX SHOCKS ALL AROUND. MY BROTHER'S 87 CAMARO HAS THOSE SPRINGS, BUT NO BOUNCE. MINE RIDES LIKE A ROCK HIS IS DECENT. ANY IDEAS OUT THERE?
Old Nov 12, 2009 | 03:13 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
Re: FRONT END BOUNCE.
you need a faster rebounding strut/shock.
get some konis and try again.
rededited was thinking koni and wrote kyb my bad
Old Nov 12, 2009 | 07:13 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Who goes down bumpy rough country roads in a thirdgen at 65 mph? Jeez.
Old Nov 13, 2009 | 08:47 AM
DONNYBAKER's Avatar
I DID SAY I HAVE KYB AGX SHOCKS ALL 4 CORNERS.
Old Nov 13, 2009 | 02:58 PM
Tpx's Avatar
Tpx
Car: 1982+1988 Z28 Camaros
Engine: 1982=350 carb 1988=383 Carb
Transmission: 1982=4 speed T-10 1988=6 speed T56
Axle/Gears: 1982=stock
don't write in caps and you might get more responses
Old Nov 14, 2009 | 08:47 PM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
what the hell kind of response is that? either:
a) answer the question
b)STFU
anyhow. i'm running a trimmed v6 spring, no front sway bar, and bone-stock 240K mile strut....but i mostly drag race the car and appreciate the suspension articulation.
look at the basics first. make sure you're sway bar end links and bushings are in good shape and not rotted out or missing hardware. if they're in bad shape, replace with appropriate poly-bushings.
i assume the part number you have is a MOOG part number...it looks like it (two letters followed by four numbers). if so, they're good springs. i also believe that the bounce has nothing to do with springs, but rather with your bouncing dampeners (ie, struts, sway bars, bushings, etc.) so maybe start there.
how many miles are on the kyb's?
Old Nov 14, 2009 | 11:32 PM
IROCK ZZ's Avatar
Car: 1986 IROC-Z
i have full koni suspension, its the way to go
and i go down rough country roads at 65mph, no problem
Old Dec 16, 2009 | 08:11 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
did you try softening the adjustment? there are 4 settings.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
