good swaybar
Old Nov 22, 2009 | 02:07 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Axle/Gears: moser 12 bolt spool 4.11
good swaybar
need to get a new bar to help the car launch a little more level. i was told that if i just put an aftermarket bar in such as the one spohn sells it will help tremendously without buying the 400 dollar drag one. help me out.
Old Nov 22, 2009 | 03:43 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: good swaybar
a larger, stiffer rear bar will keep the car from rolling as much when you launch, but the largest factory one you will find is 24mm.
Spohn makes the drag bar, UMI has a nire one, i think BMR makes one and racecraft, and wolfe racecrraft make antiroll bars, some require welding, others dont.
Old Nov 22, 2009 | 08:35 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: good swaybar
http://www.spohn.net/shop/1982-1992-...-Rear-Bar.html
is this a decent bar? and will it help me out for what im doing. how big is our factory rear bar? i see this is 1".
Old Nov 23, 2009 | 06:24 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: good swaybar
thats pretty much the same size as the largest stock size. Depending on what you have now, it could be an improvement. Need to measure what you have first.
If its more of a drag car than a street car, you would benefit by the larger drag bar that spohn sells, even though it cost more.
Old Nov 23, 2009 | 10:50 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: good swaybar
did a quick search. what bars can i run i have a stock gas tank.
Old Nov 24, 2009 | 06:25 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: good swaybar
whats the gas tank have to do with sway bars?
Old Nov 24, 2009 | 06:35 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: good swaybar
i saw a few that requires you to have a fuel cell. but i also found a bunch that will go with stock stuff. how does everyone like the wolfe bar?
Old Nov 24, 2009 | 06:38 PM
1988-305-tbi's Avatar
Re: good swaybar
never heard of the gas tank effecting the swaybars?????? the factory sizes range from 19mm-24mm the spohns is 25.4mm and made of stiffer steel, i have run both the 24mm and spohn 1" swaybars the spohn is way stiffer than the factory 24mm, if you have a 19mm or 21 mm, the factory 24mm or 1" spohn bar will make a huge difference
i have never heard of the wolfe bar????
Old Nov 24, 2009 | 06:48 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: good swaybar
the wolfe racecraft bar and kind of a universal bar, it has a torsion bar and tube that welds tot he chassis and links that weld to the axle, so i can see it needing a fuel cell and being in the way of the stock tank.
UMI has a new 1.25 rear drag bar setup thats pretty sweet, almost 400 bux though, but its a bolt in deal, with a welding option. Works wit the stock fuel tank
Old Nov 24, 2009 | 10:24 PM
BNBZ28's Avatar
Car: 86 camaro
Engine: 385
Transmission: glide
Re: good swaybar
def like the look of the umi one. looks like the spohn and a hair cheaper. probly end up getting that one. the fact that its new means there probly isnt anyone on here that has one.
Old Nov 25, 2009 | 07:41 AM
BMR Sales's Avatar
Former Sponsor
Re: good swaybar
How bad does the car roll (or twist) on launch?
Old Nov 25, 2009 | 09:48 AM
UMI Sales's Avatar
Re: good swaybar
Thanks Guys for considering UMI Performance! If you are interested feel free to check out our website starting tomorrow and you might be surprised....
Thanks Again
Brad
Ghettobird52
Jul 5, 2024 11:18 PM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
