competition engineering subframe connectors any good?
Old Dec 2, 2009 | 08:39 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
competition engineering subframe connectors?
any good?
any pros? cons?
Old Dec 2, 2009 | 08:55 PM
blue85305's Avatar
Car: 1984 camaro
Transmission: th 350
Axle/Gears: 3:42
Re: competition engineering subframe connectors any good?
wondering that myself
Old Dec 3, 2009 | 11:19 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
Depends on which ones your looking at. I origionally purchased the competition engineering kit with the cross bar and the guy who did my install said it was overkill since the floor pan would have to be cut and that particular kit was more for a roll cage setup. He installed UMI's sfc's for me and I couldn't be happier.
Old Dec 4, 2009 | 11:24 AM
UMI Sales's Avatar
Great to hear that you are satisfied with the quality of products that UMI Performance has to offer! Just another option for you to consider. We do offer a weld on SFC and below is a link to show you what we have to offer!
http://www.umiperformance.com/catalo...93jivatbf8ihq7
If you have any other questions feel free to ask and I will be more than glad to help.
Brad
Old Dec 23, 2009 | 01:48 AM
JeffG3209's Avatar
Car: 1992 Z28 Coupe
Engine: LB9
I have just started researching SFC's. I am wanting to get a set ASAP. However, I do not want them to compromise the "stock" look my car has. Can they be seen from eye level?
Old Feb 25, 2010 | 11:24 PM
Sgt. 56's Avatar
Car: 84 Z28
Engine: 454
Transmission: LT1 T56
Axle/Gears: Moser 12 Bolt Posi with 3.73 gears
So on the UMI sfc why is there 3 pieces? Just wondering is these cause problems with clearance on bbc applications with hooker super comps. Thanks.
Old Mar 6, 2010 | 03:05 AM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
the third piece is to clear the stock cat in your exhaust
Old Mar 7, 2010 | 02:18 PM
babyrat307's Avatar
Car: 85 camaro
Engine: Built 1969 307 chev
Transmission: w/c t-5
Axle/Gears: 10 bolt 3.73
HI, I have a camaro with competition engineering 247-3111 connectors. IMO they are the most beneficial ones the market. They tie in well with the front sub frame and in the rear LCA area. Now they are advertises as bolt on ones but many guys like myself weld them in for additional strength. The main Con is the fact that you can not use the factory exhaust routing but I felt that was a small price to pay to try to prevent body damage with a health SBC. Another great thing about these is they offer great lift points (stand point) for the car you don’t have to worry about damaging you car. The pictures attached are of them on my car I have had them on for 5 years and yes they make a very noticeable difference in chassis stiffness.
Attached Thumbnails competition engineering subframe connectors any good?-sub-frame1.jpg   competition engineering subframe connectors any good?-sub-frame2.jpg   competition engineering subframe connectors any good?-sub-frame3.jpg
Old Mar 8, 2010 | 01:46 PM
UMI Sales's Avatar
Hello
We offer it in 3 pieces to allow you place it anywhere away from the exhaust you want so there is no clearance issues. If you have any other questions feel free to ask.
Brad
Old May 2, 2024 | 11:41 AM
JoeyFleener7's Avatar
This maybe a long shot but could you post more pictures of your exhaust setup? I’m going to be these same SFC and am needing ideas for exhaust
Old May 2, 2024 | 12:27 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
I've put these connectors on both of my cars. One was a stock height drag car with long tubes where I ran the exhaust around the factory subframe and trans mount, unaffected by the connectors. The other is a lowered twin turbo street car with full single 4" exhaust in the factory location. I notched the connector braces on the passenger side to allow for clearance, and it's worked out great.
Ghettobird52
Jul 5, 2024 11:18 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
