Steering wheel wobble
Old Dec 15, 2009 | 10:43 PM
carfreak614's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Axle/Gears: Open 2.73
Every once in a while, my steering wheel will start to wobble back and forth, usually moving up to an inch back and forth, then it will go away for a period of time and then start again. It especially likes to do it when its cold out. Any ideas?
Have replaced the tie rod ends, sway bar end links and mounts with polyurethane, and shocks. It has also been lined up not too long ago and its still doing it.
Old Dec 15, 2009 | 10:56 PM
Stephen's Avatar
Car: 87 GTA
Re: Steering wheel wobble
Sounds like death wobble on a lifted Jeep, but I have no clue why a 3rd gen would do that.
Old Dec 16, 2009 | 02:28 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Maybe its a power steering thing???????
Use a turkey baster or suck the resivor dry with a hose and fill with new fluid.
Can only help having the fluid freshended up if its that or not.
Old Dec 16, 2009 | 08:07 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
I'm not sure if this will help you. But every time I drove my car for the first time after being stored for winter (for about 6 months) I had this issue. And after the first drive, it never did it again the whole summer. It did this since I owned it.
Anyway, I noticed my idler arm was kind of sloppy. I put in a MOOG replacement and it has never done it again. Even for the first drive of the year. I'm not sure if a bad idle arm would cause this, but that's my story.
83 Crossfire TA
Jan 3, 2016 01:26 PM
FormulasOnly
Sep 6, 2015 10:42 AM
SG91camaro
Sep 5, 2015 10:27 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
