10 bolt swap
Re: 10 bolt swap
I've got the fourth gen in there but it's a non posi and it's a 323 or some bs like that that's why I'm asking if the gear change over or not I have it in the air and haven't ran it yet so i don't wanna tear it apart If
it's not gonna inter change
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: 10 bolt swap
Technically, they're the same however the carrier series may be different. The 4th gen's 3.23 is probably a 2 series. You have 4.11 so they're probably a 3 series unless they're designed to fit on a 2 series carrier. If you just want to put in the 3.23 with gears and carrier, it's a direct swap however, the 4th gen will also use 28 spline axles. Only 90-92 third gens have 28 spline axles. Older models can easily be upgraded. 4th gen axles won't fit into a third gen housing because they're too long.
Putting the 4.10 gears and posi into the 4th gen diff is a step backward because you'll need to buy aftermarket 26 spline axles for the 4th gen or buy a 28 spline posi.
ambainb
Apr 25, 2016 09:21 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
