Power Rack & Pinion???
Old Jan 14, 2010 | 08:12 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I was wondering if there existed a power rack & pinion setup that offered the smoothness of R&P but maintain the IROC style turning radius? I've never really found any that seems to do this... I know there's tons of manual R&P but that's usually for drag racing..
I'm aiming for a street car that's made to handle amazingly, but that is somewhat smooth and as comfortable as possible..
Anyone know if this exists?
Thanks!
Old Jan 23, 2010 | 10:12 AM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
Re: Power Rack & Pinion???
No kit exists. You have to make it. I'm running a ford style rack with the racecraft short steering arm spindles. Most of the k-members you will find are for the old pinto manual rack setup. I had to make my own mounting points on the k-member in order to fit my rack.
Old Jan 23, 2010 | 11:46 AM
Oh well... I guess I'll just stick with a Lee Performance 670 steering box then! Thanks man,
-Marc
Old Aug 26, 2010 | 07:54 PM
littletimmy9's Avatar
hi red your post and would like to know what kind of ford rack did you get i my hands on one the other day and would like to know if i could make it work and did you have to go with the race craft spindles could you use the stock one at all and one last thing would you happon to have any pics of what you have done thanks
Old Aug 31, 2010 | 07:58 AM
_87TA_'s Avatar
Car: 1987 Trans am
I would also like to know.
Old Aug 31, 2010 | 03:26 PM
fast377's Avatar
Car: 91 Z28
Transmission: t-56
You should be able to make any of the ford racks work. I'm using a 97 thunderbird rack. I believe it has the most travel. But you HAVE to use the Racecraft spindles...that way you keep your turning radius stock. You will just have to fabricate mounts and a steering shaft.
Old Sep 1, 2010 | 06:08 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Take a look here. It's a power rack
http://www.camarotech.com/steering.html
Here is a list of dealers for Appleton products.
http://www.appletonrackandpinion.com/4619.html
Old Sep 1, 2010 | 05:19 PM
i have seen that one before and did some research on the appleton racks and all the people i heard from said the racks was junk and looked in to the kmember to its a old design and dont make it any more thanks any man
Old Sep 1, 2010 | 05:21 PM
thanks man
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Sep 29, 2015 01:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
89fast5oh
Aug 24, 2015 08:14 AM
overdriv
Aug 20, 2015 03:52 PM
