Frame Rail Repair for SFC?
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I have a set of weld-on subframe connectors that I would like installed on my car but I might have a problem. My front frame rails are pushed in on the bottoms. Where they are supposed to be flat they bow inwards. Will this be a problem when welding the sfc's in? If so, what can I do to fix them?
Car: 85 Iroc-Z
Re: Frame Rail Repair for SFC?
They are not rusted, they are just bent inwards some from being jacked up on. I'll will try and get a picture when I get a chance.
Car: 86 Trans Am
Engine: 408 stroker sbc
like mad max said, most SFC,s wont attach there, they attach more to the sides of the subframes. Hold up the SFC to the floor and see if you need to do anything to eh rails, most likely you wont have to
88SS6SPEED
Nov 11, 2015 07:05 AM
