weight distribution numbers?corner weights?
Old Jan 26, 2010 | 02:18 AM
Midniteson2's Avatar
Car: 1991 Firebird
Axle/Gears: 3.42 w/auburn racers diff
i have searched every where and can not find what the weight distribution for a stock v8 thirdgen. im assumin it would be about 60/40.Anyone know what they said from the factory? anyone ever corner weighed their stock thirdgen?
Old Jan 26, 2010 | 12:33 PM
Guest
Guest
Posts: n/a
Re: weight distribution numbers?corner weights?
they vary greatly depending on the Make model and year (Firebird, gta, IROC, Belinetta (sp?), Z28, etc)
These cars overall eights vay from about 3100- 3800 lbs.
All bias' are different based on model and options.
THere is a post somewhere that lists factory weights from the build sheets. I will search build sheets and see if I can find it for you. I do recall I had the closest in 50/50 bias even when my car was stock, but I was also a lightweight nosed Vr with a special "IROC looking'' Calif only package that weighed in a little heavier in the rear than most V6's do If I recall, mine stock was aprox 57/43...Ill check.
Old Jan 26, 2010 | 12:48 PM
Guest
Guest
Posts: n/a
Found it. I was 55.4/44.6. most are in the 59/41 range.
I later reduced this slightly more through extensive modifications but mostly greeatly reduced polar weight at the extremities from the car's center of gravity so it would transition alot quicker than any 3rd gen you wil see on the street with full creature comforts (meaning I did not gut this car like a race car cockpit to make it light and agile) I concentrated on reducing rear exhuast weight, Front bumper weight, axle weight, suspension assembly weight, I did remove completely the spare tire and crap (AAA plus roadside service). Just alot of little things that all add up (Lightweight mimistarter, headers, aluminum parts,Carbon fiber driveshaft, the list goes on and on. Overall though, the car eneded up heavier in weight due to the extensive Chassis bracing I added as well as the heavy Dynomate I lined the cockpit floorboard with, but did remove carpet padding and install aftermarket lighter carpet kit and much lighter Momo seats and bracket. I never put the car onto scales, I just never got around to bothering to see, just like I have never bothered to see any of my street cars on a dyno- I do kindof wish now that I had for info sake.
5 things affect chassis dynamics.
1) this subject of Weight Bias front to rear.
2) Vehicle roll weight (Height of CG or center of gravity)
3) Polar weight (Yaw motion)
4) Overall vehicle weight
5) Unsprung weight- this one is the one that really cost money.
https://www.thirdgen.org/forums/susp...t-invoice.html
If you can move weight, move it to the center of the car, move it from unsprung to sprung, move it lower, or remove it entirely.
Some things are a give and take. To add perfomance, generally weight needs to be added to the chassis for bracing. So lighting weigh off suspension parts and adding chassis weight for bracing equals sometimes a wash in overall weight, but is a major advantage in ride quality and mechanical grip.
Old Jan 26, 2010 | 03:29 PM
Dscott's Avatar
Car: 89 Iroc street car
Engine: Fitech vortec 400sbc/T5
Transmission: Also 69 Chevelle, Nascar chassis
Axle/Gears: 700hp roadrace track day car
did you trunk mount your battery?
Old Jan 26, 2010 | 10:16 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
I scaled my '83 SE a while back:
56.5 front (empty)
55.8 front (w/ me)
383
Alum heads
subframe connec
trailer hitch (gadzooks!)
PurelyPMD
May 5, 2016 04:57 PM
fbodyfreakls1
Oct 6, 2015 06:34 PM
drptop70ss
Oct 4, 2015 09:44 PM
roysatikas
Sep 7, 2015 08:08 PM
SG91camaro
Sep 5, 2015 10:27 PM
