Strano 3 Way Adjustable Rear Sway Bars (Not just for drag racing)
Old Feb 7, 2010 | 12:20 AM
Chicago89RS's Avatar
Car: 1989 RS Camaro
Engine: 305 TBI
Transmission: 700-R4 with Overdrive
Hey Strano Performance Parts offers a 3 way adjustable rear sway bar for 82-92 camaros! I'm not sure if this is new information, i tried searching the message boards and didn't find anything. Anyway the bar is 22mm and costs $250.00 w/ hardware etc.
http://www.stranoparts.com/searchbym...=124&ModelID=9
Old Feb 7, 2010 | 06:03 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Re: Strano 3 Way Adjustable Rear Sway Bars (Not just for drag racing)
I cant imagine that those 3 mounting holes give much difference in stifness. However, I do like that type of endlink better than the stock style "bolt with washers on it" style. And, the fact that it's bolt-on is nice.
Old Feb 7, 2010 | 12:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
thats pretty nice.
Old Feb 7, 2010 | 12:40 PM
Guest
Guest
Posts: n/a
on the contrary, that change in mount position is a major difference in leverage. Sortening the leverage arms makes the bar much harder to twist thus stiffening it.
We already have a slight bit of adjustment on our stock bars via the axle tube mounts. Not as much as this, but we do have a little by changing the width of the stock mounts. Inward will soften the bar, outward spread will increase the bar stiffness.
Dean
edit: one problem with the add though......Where is the 22mm position? One would assume it has to be the center setting? What is the adjustment range? Terrible ad description. You would have to call him to find out the adjustment range. Who know's, it could be 22- 25, 18- 26, 12- 22..... so what is the range?
Old Feb 7, 2010 | 02:12 PM
blyth18md's Avatar
Car: 82z28
Engine: 406
Transmission: th350
Its the hellwig bar. Im not sure if there site(hellwig) has anymore of a description. It has been discussed on frrax pretty thoroughly, a search will likely dig up the details.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
z28addict8490
Aug 7, 2015 08:48 PM
