S-10 Manual steering
Car: 91' RS
Engine: 310 C.I.D. + n2o
Axle/Gears: built 10 bolt 3.73's
I heard of people doing this conversion using a manual steering box from an S10. Can anyone tell me how hard is the steering?? I've heards its not to hard to steer and some say keep the power steering because it will be really hard. I am planning on running skinnies up front so it should be easier i hope. The car is driven alot so i would like to know if it will be an issue of the steering wheel beong to hard to turn. Can anyone give me some info Please
Car: 1982 Camaro
Engine: 555 BBC
Transmission: TSI Glide
Axle/Gears: Aluminum Moser 3.89
Re: S-10 Manual steering
I have one and it bolts right in. No issues with steering at all. A few more turns then a Z28 box.
Car: 1989 Camaro RS Drag Car
Engine: SBC 388 Stroker 93 pump gas
Transmission: Built turbo 350 3500 tci converter
Axle/Gears: Stock axles 4.10 gears
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I just drive mine around in the pits so it's hard to give a good opinion. The only difficulty I have is sharp turns like turning in or out of my pit space. I have to do a hand over hand steering to make the turn. While driving, I don't notice anything at all.
Don't use a small steering wheel. It will only make it worse.
Car: 91' RS
Good to hear thanks for the info all of you. I will deifnately do this im going to start driving the only drive my car on the weekends after i get a daily driver in a month or two so it wont be to big of an issue. Joined: Apr 2004
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I did it on my car and I love it. Definately free's up quite abit of weight. It took alittle getting used to at first, driving around in parking lots can be alittle bit of a chore but it's not too bad. I prefer it because there's quite a bit more "road feel" in my opinion.
Car: 1982 Camaro
Engine: 555 BBC
I wouldn't expect to see a ET reduction just on a steering box replacement. It's just part of the process of lightening the car and freeing up space under the hood.
Car: 2005 Chevy Colorado/ 1985 Z28
Engine: fast burn zz4
Transmission: th350
Axle/Gears: 10 bolt (has to go) 3:23 gears
i did this to my last 2 drag projects and i would def. recomend it.. steering isn't difficult in the "hard to turn the wheel" way, but it does take more turns of the wheel to make tight turns. i think i got mine from an 85' s-10 with a manual transmission.
I use mine as a daily driver and it doesn't bother me a bit. I say go for it.
Look for an 84+ iron duke (?) S10. You want the box with a 4 bolt top cover. Just to let you know that at first the car is going to be a BITCH to turn during LOW SPEED driving i.e parking lots or what not until you get used to it. After that it's not a big deal at all. Once to start to swap it over you'll need to put the Camaro pitman arm on the steering box to keep proper geometry. Luckliy when I got mine it was rebuilt and came out of a Camaro that a friend had already set up for it, so all I did was just swap straight over.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Has anyone tried swapping to the S-series idler arm when they did the manual steering swap, and just keep the S-series pitman arm on the box? Seems like that would be easier for most people, and it should reduce steering effort.
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
any parts stores rent the tool free of charge.
the only trouble you will have is an extreme hard left while sitting still, or maybe some difficulty with parallel parking.
its not going to make you any faster, but it does clean up things under the hood. no more worries about burning a pump or popping a line either.
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
I tried it in mine for a day or two and took it back out. Driving it wasn't bad and I liked the way it freed up a bunch of room under the hood. What I didn't like was the number of turns to go lock-to-lock, the effort required(13" steering wheel), and the fact that I have to parallel park my Camaro every time I come home. For what I want out of the car, its just not a good fit for me. If I was building more of a straight-line car I would have kept it, but I am aiming for handling and corner-carving so its just not worth it.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
you need to use the camaro arm.
I don't have an S-series manual steering box on my car anymore, I'll be using manual R&P to lose even more weight, but I am just curious if the S-series idler arm can be used.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
But if you have to parallel park everyday, manual steering probably isn't for you.
Car: '84 Z28
Engine: 406 sb
Transmission: th400
Axle/Gears: Moser M9/5:14 ratio/Billet Locker
I guess the main reason I decided to go with a manual box is because after I hit 7,000 rpm I get oil all over the outside of the pump. I got tired of cleaning it after each drive. Plus, with power steering gone the engine bay looks cleaner. The s10 box only cost me $20.00 from the scrap yard. I still have the car in pieces and haven't driven it yet.
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
82-93 S10/S15/Blazer/Jimmy, it's the 80s boxy body style. You'll have to look around a bit though, because I think it was only the really base line trucks that got manual steering.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
I think you are misunderstanding me. I swapped to an S-series manual steering box a long time ago, and I did swap on the F-body pitman arm, but I was wondering if the S-series idler arm can be used instead to reduce steering effort.
Steering wheel diameter doesn't make much difference in steering effort. Most of the difference is made by vehicle weight, pitman/idler arm length, and steering arm length. Have you ever driven an S-series truck with manual steering? Even with a tiny steering wheel, they are very easy to steer.
my pinto rack turns easier than the s10 box ever did, but my steering arms are modified.
Car: '84 Z28
Engine: 406 sb
Transmission: th400
yea, i got that spray too. one reason why i got rid of it. you can switch to a small cavalier type pump and eliminate the problem, but for race, rack and pinion is the lightest option with the most room in the engine bay.
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
My Camaro was much more difficult to steer, but overall wasn't that bad, and it had the stock Z28 steering wheel. It had a little more front end weight, but the main difference was because it had shorter steering arms and longer pitman and idler arms.
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
http://www.jegs.com/i/Unisteer/668/8060200/10002/-1
other brands are available. you can get a stock replacement from the parts house as well, for prolly half the price.
buddy of mine had one on his s10, another friend has one on a camaro.
it uses a remote reservoir.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
