lower controll arm relocation brackets.
Old Feb 11, 2010 | 12:44 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
alright here is the deal im considering lowering the car. 91 firebird ws6. i want the looks and a little more ability in the corners but dont want to loose my dead hook at the track. ive got spohn adjustable everything in the rear wat im wanting to know is if i lower it is there any to adjust the geometry back to where to was? im thinking not but i just want to verify.
Old Feb 11, 2010 | 12:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: lower controll arm relocation brackets.
come again? hard to rear the last couple lines
the relo brackets will allow you re re-level the arms to correct the stock geometry. They for track days, you can lower the arms more to gain some extra grip
Old Feb 11, 2010 | 03:38 PM
BMR Sales's Avatar
Former Sponsor
<86TA> is exactly right. You are going to need lower control arm relocation brackets to get the lower arm geometry corrected. If you don't already have an adjustable panhard bar your going to need one of those too. We offer both bolt on and weld on relocation brackets. Both versions are made from strong 3/16" laser cut, cold rolled steel. You get an added 3" of adjustment for your lower control arms. If you have any questions or would like to get a set on the way give me a call here at the office.
Old Feb 11, 2010 | 05:55 PM
ziggy89's Avatar
Engine: 383
srry the computer at work is hard to tye on and i dont usually proof read.
wat i want to do is lower the car for more corning ability but want to keep geometry the same because i dead hook at the track on street tires.
Old Feb 11, 2010 | 06:00 PM
ziggy89's Avatar
Engine: 383
A. installed pics of both types?
B. why are the bolt in applications not compatabile with aftermarket rear ends?
Old Feb 12, 2010 | 09:41 AM
BMR Sales's Avatar
Former Sponsor
You can use the brackets but put the arm in the middle hole which should put the arm about level. I don't have any instyall pics of either part installed. The bolt on brackets have a tab the go to the shock mount. On an aftermarket rear they use a different style of shock mount tabs so they dont fit right.
You can use the bolt on brackets on your stock rear then weld them on to an aftermarket rear end. All you have to do is cut the shock mount tab off of the brackets and they will fit fine.
Old Feb 12, 2010 | 10:46 AM
Guest
Guest
Posts: n/a
It can't be done. look at your launch picture and your weight transfer fore to aft. look at you nose rise. With all of that , you lower the car and that load transfer will change. you want cornering? you can not run those 90/10 struts. Your spring rates will change, your vehicle dynamics will chnage through a lower center of gravity. you will have to rework the entire suspension when youlovwer it to get it to hook like that again.
how will it then handle? handling depends mainly on chassis control. Drag laungh and cornering required two completely different ways of chassis control to acheive goals. Both can NOT be done unless you spend major busks on double adjustable shocks and struts and a few hours of changing wheels and tires and then readjusting the entire suspension each time you ewant each setup. might as well buy a second car.
Dean
Old Feb 12, 2010 | 12:25 PM
ziggy89's Avatar
Engine: 383
i dont run 90/10s lol. those are stock front struts, rear shocks, and springs. and it doesnt launch quite like that anymore with the tubular rear suspenson
deracer
Apr 11, 2016 12:04 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Dialed_In
Aug 20, 2015 01:45 PM
