LCA relocation question
Old Mar 8, 2010 | 06:25 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
sphon has a good deal on lca relocation brackets and mention they can be used with stock height cars.
i read even with stock height you get better traction
is this true/worth it?
im putting in SFC's from UMI and while im under there i figured id replace the stock lca/panhard bars and then i noticed the relacation brackets.
this is for my fun ride/daily summer driver. not for racing. but i like it to handle ebtter than stock like a champ ya know.
Old Mar 8, 2010 | 06:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LCA relocation question
well, for the best handling, the lca want to be about level, if you lower the axle side you can get better straight traction, but traction in turns will suffer
Old Mar 8, 2010 | 06:31 PM
Bobby_80s's Avatar
Axle/Gears: no idea
oh ok good to know thanks, yea not for my needs then
Old Mar 9, 2010 | 10:10 AM
UMI Sales's Avatar
Hello
Like mentioned above the relocation brackets will increase your traction performance as for straight line performance. And also help eliminate wheel hoping issues. But if the vehicle is a corner carver then you will notice a little bit of over steer. I also noticed that you had a set of our SFC's and I wanted to thank you for the business. Below is a link to show you what all we have too offer!
http://www.umiperformance.com/catalo...7hp3l5katkrpf2
If you have any other questions feel free to ask!
Brad
Old Mar 9, 2010 | 04:19 PM
92-Formula's Avatar
but using LCA brackets after lowering the car are still neccessary for proper handling, correct?
Old Mar 9, 2010 | 04:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
it can be because the arms are angled up toward the axle when the car is lowered, so the lcarb can help re;level them
Old Mar 9, 2010 | 04:43 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
there is a super long, super confusing sticky on this.
Old Mar 10, 2010 | 09:59 AM
UMI Sales's Avatar
Hello 92 Formula
Like 86 TA said hes is correct. The relocation brackets allow you adjust the lower control arm back to the correct angle. Seeing how when a vehicle is lowered the front of the control arm is higher than the rear (axle). Now with the brackets they eliminate the wheel hop issues due to the incorrect angle and gain back your traction performance that was lost. If you have any other questions feel free to ask.
Brad
Old Mar 10, 2010 | 04:50 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
other way around.
Old Mar 11, 2010 | 08:40 AM
UMI Sales's Avatar
Originally Posted by AM91Camaro_RS
other way around.
I understand...I think you might have misunderstood me! I was talking about when you install the brackets on a lowered vehicle then the front of the control arm will be higher than the rear (axle) side. Sorry for the misunderstanding.
Brad
zayne0
Aug 24, 2015 07:22 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
redmaroz
Aug 16, 2015 11:40 PM
NBrehm
Aug 5, 2015 07:57 PM
