Handling problem
Old Sep 15, 2000 | 12:04 PM
Blk350Camaro's Avatar
Handling problem
My 1985 Camaro is handling terribly. When I am going down the highway @ about 65-70mph, the car almost feels like it is swaying from side to side. It won't track down the road right. The alignment is good and the tires are also fine. I noticed that the front end of the car is sitting up higher than the back. However, the rear springs and shocks were replaced with factory replacements. I found out that the lower tie bar is missing from the car, and that part is on order from Michigan. It bolts up above the front sway bar. I would like to upgrade my suspension, but I would first like to be able to drive the car down the highway without fighting it the whole way. Please help, I am really lost?!?!?
Black 1985 Camaro Sport Coupe
1993 350
700R4 Tranny
3.08 gears
Comp Cams 268H Cam
Crane Double Roller Timing Set
Edelbrock Performer Intake
Weiand Open Element Air Cleaner
K&N Filter
Edelbrock TES Headers
Dynomax CVX Cat-Back
Crane HI-2000 Ignition
Crane PS-91 Coil
MSD Superconductor Wires
ADS Strip Chip
160 Thermostat
CK Secondaries
Old Sep 15, 2000 | 03:56 PM
wm_sorg's Avatar
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
Does the car seem to wander from the rear. I had a similar problem with my 87 formula years ago. The car would sway side to side from the rear as if the car was not attached to the rear axl.
Eventually, I found that one of the trailing arm bushings was worn from where it was pressed. Even though the bushing was good the trailing arm was free to drift around it causing the axl to yaw side to side.
Replacing the trailing arm was not an easy task. Soak those bolts down a few days before the job. Good luck!
fasteddi
Sep 10, 2015 09:32 AM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
greenyone
Sep 2, 2015 03:39 PM
masonta
Sep 1, 2015 06:40 PM
