quick questions
Old Mar 15, 2010 | 05:29 PM
Louis_84's Avatar
Car: 1984 Camaro SC
Engine: 305 V8, LG4. For now...
Transmission: 700R4, for now...
Axle/Gears: ???
quick questions
Hi guys
Ok, so I was thinking of getting a new adjustable panhard bar, and a new adjustable torque arm. One reason I wanted to get these is because when I lower my car in the future I can make proper adjustments. My first couple of questions are...Are aftermarket torque arms, and panhard bars lighter than stock ones? Also I read that the stock torque arm will flex alot (waste of power). Is that true? Lol my car prolly doesnt have enough power to bend paper, but i want to put a new engine in some day.
Its prolly better to take weight from the front rather than the rear, but this is just one way I thought of losing a little bit of weight. But the main reason i want them is because I just want to make baby steps to make my car better.
I dont know if it matters but I have a 84 Camaro sport couple with a 5.0L
Any comments welcome!
Old Mar 15, 2010 | 06:04 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: quick questions
you can twist the stock panhard with you bare hands, and the torque arm is pretty flimsy. The aftermarket ones weight more, but not a lot more dpeenmding on which ones you buy. you can usually tell by the pics which ones are heavier. Most are made with the same size round tubing, but the webbing between the upper and lower tubes vary from one builder to another.
Old Mar 15, 2010 | 08:18 PM
Louis_84's Avatar
Car: 1984 Camaro SC
Axle/Gears: ???
Re: quick questions
Oh well thats a little lame,I was really hoping that they would at least weigh the same. But I really appreasiate your input.
I also thought of a new question. I read that you need an adjustable panhard bar when you lower your third gen, does the torque arm need to be adjustable too if you lower the car?
Old Mar 16, 2010 | 02:12 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
Re: quick questions
most lowered cars need an adjustable panhard bar to relocate the rear side to side. torque arm isn't necessary for lowered cars but for the smoothest ride possible as well as the other benefits it gives would be a nice addition.
Old Mar 16, 2010 | 07:30 PM
Louis_84's Avatar
Car: 1984 Camaro SC
Axle/Gears: ???
Re: quick questions
What are some of the other benifits? A aftermaket torque arm will make the ride smoother?
Old Mar 16, 2010 | 09:12 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: quick questions
i think he meant the adjustable torque arm. Dont waste your moneys on a non adjustable arm. To properly set the pi9nion angle, you need the adjustment.
As for the aftermarket arms weighing more. to be stronger, you sometimes need to be a little heavier, its really not a big deal, and we are not talking a major difference in weight, a couple pounds depending on brand.
It would be interesting to actually get real world weights on these parts, i dont think people generally weight them
Old Mar 17, 2010 | 02:54 AM
matthufham's Avatar
Car: 90 z28
Transmission: t56
Re: quick questions
well when you lower a car the pinion changes which can change driveshaft/rear end angles and produce vibrations. not a big deal moving the rear up an inch or so. i'm used to trucks where i lowered mine 6 inches, or others will lift it 6 inches easy... but the difference is alot more extreme making pinion changes much more necessary. your camaro is built to ride just fine with the stock pinion angle from bump stop to max lift which is a range of like 3 or 4 inches at most.
Old Mar 20, 2010 | 04:22 AM
Louis_84's Avatar
Car: 1984 Camaro SC
Axle/Gears: ???
Re: quick questions
so how do you fix the pinion angle?
Old Mar 20, 2010 | 07:28 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: quick questions
with an adjustable torque arm
Old Mar 20, 2010 | 03:17 PM
Louis_84's Avatar
Car: 1984 Camaro SC
Axle/Gears: ???
Re: quick questions
Oh, ok. does an adjustable torque arm just change length?
Old Mar 20, 2010 | 04:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: quick questions
no, the rear of the arm, where it bolts to the axle, has an adjuster on the bottom, you can lengthen or shorten the lower adjuster, and that changes the angle of the axle housing up or down, changing the pinion angle.
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
