good and bad LCA's
Old Sep 18, 2000 | 10:47 PM
brian86Z's Avatar
good and bad LCA's
does anyone love or hate there aftermarket LCA's? i want them to be one of my next mods and i could use some opinions.
thanks
Brian
Old Sep 19, 2000 | 12:43 AM
Alpine406's Avatar
if you get some i would get some with poly urethane bushings.
i got solid busings on adjustable LCA`s and it sounds like tho car is going to fall apart.
they make so much noise its rediculous
Old Sep 19, 2000 | 01:13 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I have Spohn's moly rod end LCAs. They have zero deflection and no bind. They are noisey, however. I just ordered some poly ends for the frame side of the LCAs. They should quite them up and will still retain the bind free rod end on the axle side. Poly/poly LCAs are too stiff for street or autox use and will bind under high loads. If you want quiet, good ride, then get the factory 1LE LCAs. They have harder bushings then the stock pieces do.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Sep 19, 2000 | 01:27 PM
82camaro's Avatar
Car: 82 camaro SC
The best combo I've found is new rubber bushings, box the stock control arms, and use LCA relocation brackets.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
86IROC112
Apr 9, 2016 10:20 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
wruiz
Aug 11, 2015 02:59 PM
NBrehm
Aug 5, 2015 07:57 PM
