How to install struts?
Old Oct 2, 2000 | 10:51 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
What is the easiest procedure to install front struts on my '91 GTA? I've heard different ways before butwant to be sure. THANKS!!
'91 GTA:5.0-5-spd, chip, K&N,Flows,Coil,Air Foil, 350 soon to come!
'39 Chevy coupe
'52 Chevy p/u
Old Oct 2, 2000 | 02:10 PM
chevymike's Avatar
The easiest way is with air tools.
Jack the car up and place on jack stands. Remove the front wheels. Place a jack under the A arm and jack up until it just starts to load the A arm. Remove the upper strut nut. Remove the two lower strut bolts. Remove the bracket holding the brake line to the strut. Remove strut. Reverse installation. Make sure you re-torque the two lower strut bolts to approx. 160-180 flbs. The hardest part is getting all the nuts and bolts removed. This is where air tools come into play. I can do both struts in less then an hour. Good luck.
Mike Schwartz aka chevymike
'92 Z28, 5.7, Teal Hardtop
"Don't Outlaw High Performance Cars,
Outlaw Low Performance Drivers!"
Mike's Camaro Z28
Old Oct 2, 2000 | 07:23 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Ditto the above stepps. It is a relly easy procedure. I thought it was going to be a pain in the *ss, but it wasn't.
'91 GTA with TPI 350 & T-Tops. Just a few mods, if you want to find out just line up next to me at a stoplight!
Frozer!!!
Jan 19, 2024 04:55 PM
NORTz89
May 20, 2020 03:51 PM
redmaroz
Apr 25, 2017 07:14 AM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
