handling out of whack, bad
my 86 iroc rides terrible.I think it went wrong when I installed poly sway bushings in the front.the car has 130,000 miles on it and is in great shape the handling is just gone.I have had everything up front checked and its okay,I had tie rod ends and balljoints done also,but the problem was there before and after that.the idler arm was replaced 1 year ago.When I go into a turn hard it plows the front end and the rear lifts and if not careful breaks loose.it has falken 245/50/16 tires on it.I noticed when the front sway bushings were installed ,there is a 1/4 inch gap where the bushing comes together,like its too small.could this cause this problem?could it be bad struts and shocks?they are old.thanks alot
~mike~
1 superclean 86IROC-Z
Ragtop Man
Sep 12, 2015 12:23 AM
