Braided brake lines
Old Oct 2, 2000 | 10:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Braided brake lines
What manufactures make perfect-fit, braided lines for our cars?
JameS
Old Oct 2, 2000 | 01:24 PM
JeffT's Avatar
Car: 1991 Z28
Russell makes a nice 5 line kit. The ones in the rear fit perfect but I didn't use the fronts bc the Baer kit came with lines.
1991 Z28, minirammed 383, Baer Track kit and a few other goodies...stay tuned.
Old Oct 3, 2000 | 09:08 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I have the Russel lines in the front and back and they make a big difference. Before the lines were installed, the car would pull to the right upon braking. Now it stops in a straight line and the pedal is a lot firmer.
Hope this helps
Steve
Old Oct 3, 2000 | 09:55 AM
JamesC's Avatar
Steve,
Are the Russell lines a perfect fit? If so, where can I purchase them?
Thanks,
JamesC
Old Oct 3, 2000 | 02:18 PM
Tom Keliher's Avatar
5 lines??
My Russell kit came with the two front lines, plus the splitter block that attaches to the rear axle. The rear caliper lines, the ones about 3 inches long, did not come in the kit.
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Oct 3, 2000 | 02:36 PM
JeffT's Avatar
Car: 1991 Z28
Tom, my bad. I got the Russell 3 line kit and bought the rears (caliper lines) seperate from Baer. Man, it's been a long time since then!
Old Oct 3, 2000 | 04:59 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Earls sells a complete kit.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 3, 2000 | 06:28 PM
JeffT, no prob. So, Baer carries those short lines? Cool, I want some. Do you remeber part #'s? If not no biggies, I can call them.
Same for you BLACKZ, you got any part numbers for the rear lines? Thanks guys!
FORMULA 350 TK
[This message has been edited by Tom Keliher (edited October 03, 2000).]
Old Oct 3, 2000 | 08:00 PM
JamesC's Avatar
BlackZ,
Where can I purchase Earls lines? Website? Catalogue? About what is the cost per set?
Thanks,
JamesC
Old Oct 4, 2000 | 06:45 AM
BLACK Z's Avatar
Car: 86 Z28
I forgot the part number, But I found that some guy buy the name of sam works there and he was a great help,1-317-241-0318,
Frozer!!!
Jan 19, 2024 04:55 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
