Front tires hop at parking speeds
Old Oct 8, 2000 | 11:35 PM
PerthZ28's Avatar
When I'm parking, my front tires will scrub the pavement then hop as I increase lock. If reversing, they will scrub badly but when going forward, they bite in and the car pushes them forward and they hop. WTF? Is it possible to adjust toe-in/toe-out on turns? The alignment is good.
Old Oct 9, 2000 | 12:01 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Toe in is adjustable. Toe out on turns is factory set in the angle of the steering arms.
Has the cars suspension been modified? Are the front tires the stock size? Any changes other than stock will not perform as well as the stock setup. If you did any such changes, you should go get another alignment to make sure everything is within the proper settings.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 9, 2000 | 01:09 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
They all do that to some extent. The wider the tires you have, the more pronounced it will be. You should really only notice a problem at lock. Both of mine have done it since they were new and others i've seen have done it to.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
kyleb24
Aug 15, 2015 08:24 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
