1LE front wheel bearing question.....
Old Oct 12, 2000 | 12:01 AM
Jason M 91Z's Avatar
I'm converting my car to 1LE front brakes. I'm getting the Guldstrand brakets, Slotted 1LE rotors from Autospecialty, and stainless sleeved calipers from King Kaliper. I got anchor plates on order from Dal at Vandevere too. My only question right now is the wheel bearings. Would replacement Timkens for stock brakes work, or are 1LE bearings different? Also, can I get a hardware kit for the front calipers on 1LE cars from cooper or raybestos with the clip and all that garbage? Thanks in advance guys.
-Jason M. 1991 Camaro Z28
"Its Blue."
Old Oct 12, 2000 | 06:23 AM
1991z281le's Avatar
The 1LEs did use a different size front wheel bearing set. It was different in size only and not in performance. Any brand of wheel bearing for the 1LE is suitable.
Old Oct 14, 2000 | 04:03 PM
Christobal's Avatar
Last time I was at the Timken site probably a year ago they listed the front wheel bearings as follows:
Standard spindles: Inner bearing is a Set 6
Outer bearing is a Set 34
1LE spindles or as they describe it (HD):
Described the seal as a #8871 for both applications.
Old Oct 15, 2000 | 12:17 PM
So is the ID of the outer bearing inner race the same in both applications? Will I be able to put a 1LE rotor/hub and wheel bearings on my standard spindle? I'm getting those Guldstrand adapters so I can mount the PBR caliper and anchor plate on my stock spindle. I was just wondering if there was a difference in spindle diameter between standard and 1LE steering knuckles. Thanks guys.
"Its Blue."
Old Oct 15, 2000 | 03:20 PM
Christobal's Avatar
Well that's a good question. I can't think of a reason why that's not possible, but I'm not sure. I didn't print all the specs of the cups and cones in the various bearing sets I listed. The computer I'm using is pretty crappy at dealing with sites like Timken's.
You can find that info at Timken.com. I'm interested in finding out myself.
dyeager535
Aug 28, 2015 08:10 AM
kah992
Aug 19, 2015 02:55 PM
wruiz
Aug 11, 2015 02:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
