To much wheel hop, how to correct problem!!!
Old Oct 15, 2000 | 01:39 AM
Slow88RS's Avatar
Okay, I know for a fact that I need shocks and struts. My rears are shot and I'm almost pretty positive that my front struts are also. When I was at the track my 4500 clutch dumps to heat up the tires caused A LOT of wheel hop. It was horrible, I couldn't go over 2000 w/o it wheel hoping. It was horrible. I need to correct this problem fast. Please help, THX.
90 Iroc LB9 5spd G92
Dual Cats, 3.42 Borg Warner w/Posi, TPIS Airfoil, K&N, 160 Thermo, Mobil 1 Extreme Formula 0W-30 Synthetic Motor Oil, Home Made Ram Air, ACDelco Plugs, 8.8mm 300+ Accel "Race" Wires, Accel Cap And Rotor, Ported and Gasket Matched Plenum, TB Coolant Bypass, Advanced Timing To 10 BTC
Best ET(Not Corrected): 14.4 @ 94mph with 2.002 60ft
My 3rd Gen Web Page
Old Oct 15, 2000 | 11:52 AM
Chad91Rs's Avatar
All you need are some LCA's and LCA brakets.
With these you'll say goodbye to your problem.
Old Oct 17, 2000 | 03:44 PM
Max's Avatar
Max
Car: '89 Camaro Convertible
Engine: LB9 Heads/LT1 Cam Holley 670 Carb
Transmission: T5 Manual
I replaced my stock rear control arms with a set of lakewoods. They are much stronger which I believe elimintates twisting. They also have polyurethane bushings instead of rubber. They have made an incredible differance not only when launching in a straight line but also when throwing a 180.
The rear end handling is much improved overall.
Black 1989 RS Convertible w/43,000 mi.
Excellent Condition
LO3 305 w/TBI
12 PSI Fuel Pressure
6* Timing Advance
Open Element 14x3 K&N
Hypertech Thermomaster
160 Degree Thermostat
Low Temp Fan Switch
Eddlebrock RPM Muffler
No Cat/No AIR Injection
B&M Stage 2 Shift Kit
17"x9" ATP 5 Spoke Alloys
P 245/45 Goodyear Eagle
HP Ultra Plus Tires
Lakewood Control Arms
Coming Soon:
3.73 Gears
Headmann Headers & Y Pipe
Lakewood Pan Hard Rod
MSD Wires and Coil
Old Oct 18, 2000 | 09:20 PM
Jason M 91Z's Avatar
I also have Lakewood LCA's and their adjustable track bar on my car. Combined with a new set of KYB Gas-a-just shocks they eliminated wheel hop and tire rub on hard cornering.
-Jason M. 1991 Camaro Z28
"Its Blue."
Glowsock
Jul 24, 2025 03:15 PM
IroczFan
Oct 6, 2015 10:13 AM
Omega
Oct 1, 2015 02:20 PM
Fronzizzle
Aug 9, 2015 01:15 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
