If ladder bars aren't street worthy and 4-link requires tubing the car...what's left?
Old Oct 23, 2000 | 08:13 PM
crazeinc's Avatar
I was very close to buying the Comp Engineering ladder bar setup until people we're letting me know about the rough street conditions. If someone could explain to me exactly what the problem is please do so I can understand it.
And like I said in the title, since most suspension and chassis companies recommend traction bars, ladder bars, and 4-links and those are apparently out of the question on thirdgen, what are you supposed to do to keep the tires planted??
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website (New design in progress...very cool look)
(383/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 23, 2000 | 09:15 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
An explanation of the suspension can be found on http://www.calgarydragracing/4link.html
As for keeping the tires planted it all depends on your setup. I have Herb Adams lower control arms and panhard bar all with hiem joints. Steve's torque arm. Air bags in the springs. Factory shocks. That was it for rear suspension modifications. I never got a chance to properly test of the LCA relocation brackets this year. I just got some more pics of my car when it was at the track. A couple were taken as I was launching. You can see the wrinkles in the sidewall of the rear tires. Because I still don't have drag struts, the front end is still on the ground but there is a wider gap between the front tire and the fender. If you look at the pictures you can see that the rear of the car isn't squatting and I was pulling low 1.7 to high 1.6 60 foot times on a 26x10.5 ET Street.
Chassis setup and weight transfer can work wonders if set up properly.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Oct 23, 2000 | 10:26 PM
crazeinc's Avatar
Well, I could invest quite a bit of money into a thirdgen sponsor...Steve Spohn
All are with chrome-moly rod ends:
-adjustable torque arm (race version)
-fully adjustable lca's
-relocating lca brackets
-adjustable panhard rod
Wouldn't mind getting the TH350 retrofit crossmember too
1992 Trans Am
May 10, 2023 07:19 PM
9192camaro
16
Feb 3, 2019 12:21 AM
bdads
Aug 24, 2015 06:01 PM
overdriv
Aug 20, 2015 03:52 PM
Street Lethal
Aug 13, 2015 08:28 PM
