Does a 10 point rollcage (has side beams) protect you at all in a side collision?
Old Oct 26, 2000 | 06:31 PM
crazeinc's Avatar
I would like to know the question in the subject because I want to run fiberglass doors, but I still drive it on the street every once and a while and want to be safe.
82 Z28
350 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website
(Blown 355/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
Old Oct 27, 2000 | 08:04 AM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Yep, a properly designed roll cage (anything with 6 points or more) will have a diagonal beam on each side running from the main hoop down to the front corner of the floor pan (close to where the "dead pedal" is). The NHRA rules have drawings/specs on where this beam should be in relation to the driver. See:
http://www.mycar.net/mafb/registry/detail.cfm?id=48
for some pix of a Wolfe Racecraft 6-point cage.
Greg Westphal
'87 IROC 305TPI/A4
Old Nov 3, 2000 | 06:00 PM
87ROC's Avatar
Craze: Roll cages are called after the number of points of contact TO THE FLOOR/FRAME. A 6 pt cage has a main hoop (2pts), a front hoop (2 more points) and two rearward supports (2 more again). Side intrusion bars (the ones near the doors) do not count as points as they go from roll bar to roll bar and not to the floor/frame. A standard race 6 pt cage (as in my wifes 87IROC) has 2 side intrusion bars on both doors (ie 4 additional bars)and a cross member running from behind the drivers head down to the "point" contact of the passenger side front hoop. I would match the "safety" of this design against any factory "door guards".
corlando52
Interior Parts Wanted
Aug 24, 2015 11:32 AM
theurge
Aug 21, 2015 12:46 PM
Fronzizzle
Aug 19, 2015 01:36 PM
Fronzizzle
Aug 17, 2015 02:52 PM
silentkillzr
Mid-West Region
Aug 16, 2015 09:22 AM
