WS6 or 1LE Springs?
Old Oct 20, 2000 | 09:53 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
WS6 or 1LE Springs?
Are they the same, are they differant?
Old Oct 30, 2000 | 08:43 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
bttt
[This message has been edited by Mkos1980 (edited October 31, 2000).]
Old Oct 31, 2000 | 09:51 PM
Hunter Motorsports's Avatar
Car: Camaro Z28 1LE R7U
Engine: 5.0 TPI
Transmission: G-Force Dog-Ring T5
Same spring rate, possibly different trim height. You are better off putting in a set of Suspension Techniques or Eibach springs, that is if you can afford them.
Karl Hunter
Hunter Motorsports
Vancouver, B.C. CANADA
Old Nov 2, 2000 | 05:05 PM
Wraith's Avatar
The 1LE springs are stiffer than the WS6 spings, just like the sway bars are bigger on a 1LE car than a WS6.
1991 Trans Am GTA, Accel 300+ ignition, underdrive pulleys, AFPR, Accel SuperRam (ported out), Edelbrock lower intake (ported out), BBK 58mm TB, TFS 23* heads, SLP 1 3/4 headers, SLP 3" cat back (no cat), CompCam .495/.502 lift, Kenny Bell strut tower brace, lower frame brace, Jeg's SFC, Lakewood trailing arms and panhard rod
Pony's can run, but bird can fly
1987 Buick Turbo-T
1977 Chevy Blazer 4X4
Old Nov 2, 2000 | 08:34 PM
Engine: 5.0 TPI
The 1-LE springs are NOT stiffer than the late 80's - early 90's WS-6 springs. I have checked. I have multiple sets of both kind, they even have the same spring codes in many cases. The sway bars are also the same size. The 1-LE cars came with a 36mm hollow front bar which was available on 86-up WS-6 TransAm or 89-up Z-28 Camaro. 24mm rear bars are also NOT unique to the 1-LE. I have worked on so many non-1-LE cars that have the big bars and stiff springs to know this first hand. I can always find big bars and good springs at wrecking yards with ease. They are common. I have NEVER seen anything bigger or badder than these bars and springs on any stock 1-LE car. Having a 1-LE car myself, and having half a dozen 1-LE cars in the club I belong to, three of which are on my team and are prepared by me, and having worked on too many different 1-LE cars to count on my hands, I think I know what the deal is. How many 1-LE cars have you worked on Wraith?
Karl Hunter
Hunter Motorsports
Old Nov 3, 2000 | 07:26 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yeah, the 1LE and WS6 sway bars were the same, so i would assume the springs are too. The 1LE did get better shocks and the Vette brakes.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Jun 19, 2008 | 02:21 AM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
Re: WS6 or 1LE Springs?
I have an 85 t/a and i'm looking at some 1LE springs for cheap, i have no clue what suspension the car had stock, it has addco sway bars(any good?) and the rear sits very high, like, 3 to 4 inch over the rear tire, and a good inch and a half above the front, in any case, i was wondering what the consensus was on the 1LE's. I know they're about the same as ws6(i searched) but i dunno if i actually have ws6's, and my other set has 160,000 miles on them under a heavy GTA.
I also have a set of 87 WS6 sway bars on my parts car, would these be better then the addco's? Addco seems a lower tier manufacturer.
Old Jun 20, 2008 | 03:40 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Sorry guys i just re read my post and realized it didn't make too much sense, my questions are:
1) How high does a ws6 car sit stock?
2)are Addco sway bars better then 87 ws6 sway bars? Can i tell by simply looking at diameter? i know the addco's are shaped differently.
Old Jun 21, 2008 | 01:35 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
My impression is Addcos are generally decent sway bars. Addco makes aftermarket swaybars for many cars. They are US made, not just US labeled.
However, I have no info or experience with 3rd Gen applications.
Old Jun 21, 2008 | 10:43 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
hmm, i don't like the balance of the car right now, with the rear so high and and the swaybars it feels very tight and i have problems kicking it out even with decent wheel spin, maybe the posi is tired. i didn't have that problem with the GTA, though it had a 350.
MrPackstin
Oct 25, 2017 08:09 PM
jrdturbo
Mar 31, 2016 02:58 PM
darwinprice
17
Oct 11, 2015 11:51 PM
meeklay812
Oct 1, 2015 03:46 PM
Dragonsys
Sep 25, 2015 03:51 PM
