Axle U Bolt
Old Apr 2, 2010 | 02:58 PM
gholian's Avatar
Car: 82 Pontiac Firebird s/e
Engine: 2.8 V6
Transmission: TH200C
Axle U Bolt
Hi,
You know on the axle on the Thirdgens there are two large U bolts that go around the axle that attach the rear sway bar to the axle via the two bushing. Well I broke one of these. I live in Ireland and can't get any thirdgen parts here. I have spent two weeks looking in hardware shops and auto shops trying to find a U bolt that I can use but no luck. I have tried trailer U bolts, exhaust U bolts, aerial U bolts but nothing will work. I had a look on ebay also but nothing that will work. I was wondering are these readily availabe in the US. Can they be got in the likes of Autozone or Pepboys. Anyone know of an online store I could try.
Any help appriecated.
Old Apr 2, 2010 | 03:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Axle U Bolt
the stock axle is something like 2.625" in diameter. You should be able to find a muffler clamp about that size and use that, thats pretty much all those things are.
I assume a local parts store over there would have these?
seems you have tried that route, what exactly is wrong with what you are using? diameter? length?
Old Apr 2, 2010 | 05:29 PM
gholian's Avatar
Engine: 2.8 V6
Re: Axle U Bolt
I measured the axle and found it to be 2.65". I can find a U bolt that will go around the axle but it is just that little bit too short. I tried a few muffler clamps but the are too short. I tried ebay in the USA but can't get anything with the right diameter or length. It is getting frustating.
Thanks.
Old Apr 2, 2010 | 07:54 PM
brutalform's Avatar
Re: Axle U Bolt
You can have a muffler shop actually bend and thread one for you, the correct length you need.
Old Apr 2, 2010 | 08:30 PM
FUNIROC's Avatar
Car: 1989 IROC
Re: Axle U Bolt
Any machine shop can make them for as well just take the good one and tell them to make a copy of it.
We did this a lot with 4x4 trucks to get the lift we needed. They just take a rod cut it bend it then thread it done.
Old Apr 2, 2010 | 11:09 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Re: Axle U Bolt
Any spring shop can do the same. You're not looking hard enough.
Old Apr 2, 2010 | 11:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Axle U Bolt
Take an appropriate sized piece of threaded rod and bend it around the axle, then cut to length.
Old Apr 3, 2010 | 11:05 AM
brutalform's Avatar
Re: Axle U Bolt
Yea I agree. This is not even a minor set back.
Old Apr 3, 2010 | 06:09 PM
gholian's Avatar
Engine: 2.8 V6
Re: Axle U Bolt
Yes!, of course I never tought of that.
Thanks.
Old Apr 3, 2010 | 06:35 PM
FUNIROC's Avatar
Car: 1989 IROC
Re: Axle U Bolt
I am not sure I would use a threaded rod and bend it around the axle. Threaded rods are very week when bent, think of this the threads are cuts into the metal when you bend them the cuts tend to open up and break very easily.
Old Apr 3, 2010 | 06:59 PM
ternandes's Avatar
Car: 88 GTA
Transmission: WC T5
Axle/Gears: BW 9-bolt 3.27 posi
Re: Axle U Bolt
I had a similar problem with my son's 87 bird. Both of the mounts for the sway bar bushing were missing. I just used appropriately sized muffler clamps, and except for a small amount of grinding that I needed to do on the flat parts, it all went together nicely.
Old Apr 4, 2010 | 12:55 AM
brutalform's Avatar
Re: Axle U Bolt
Old Apr 4, 2010 | 06:55 AM
FUNIROC's Avatar
Car: 1989 IROC
Re: Axle U Bolt
Threaded rod to me says end to end threads. If you use a rod that is threaded end to end and bend it into a U shape it weakens the strength of the rod. As far as I remember they cut the threads into the steel. Take most any cut peace of steel and bend it at the cut and it will either break or be much weaker due to the cut in it. Not something I would use to support my axle.
I am sure I could be wrong. But I won't take that chance, to easy to get the proper part.
Old Apr 4, 2010 | 10:56 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
Re: Axle U Bolt
you're not using it to support the axle, anyway. Its holding the sway bar mount.
Old Apr 4, 2010 | 07:26 PM
gholian's Avatar
Engine: 2.8 V6
Re: Axle U Bolt
I am thinking I could buy a piece of 8mm bar, bend it around the axle as said above and then thread it an inch each side for the nuts. That's my plan anyway.
Old Apr 4, 2010 | 07:40 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Re: Axle U Bolt
that would be fine.
as for threaded rod, the threaded rod that you buy at the local hardware store is weak to begin with, if you bend it, it will break. its not something to use in this application.
Old Apr 4, 2010 | 09:41 PM
brutalform's Avatar
Re: Axle U Bolt
As posted earlier on...ANY spring shop can make one. As 86TA stated, a cheap piece will break...so a spring shop will heat it, and put it in a "U" bender made especially for this purpose, and you will have your part.
Old Apr 4, 2010 | 11:20 PM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Re: Axle U Bolt
The U-bolts are part of my rear sway bar bushing kit. I suppose I can add the U-bolts as a separate item. Mine are GM pieces that are bead blasted and plated.
Lon
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
dbrochard
Oct 3, 2015 12:43 PM
Jlanz55
Sep 6, 2015 07:28 PM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
