Changed my pads today...somethings not right, Please help..
Old Nov 5, 2000 | 06:18 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
I changed my brake pads today all the way around. I changed the wheel cylinders in the back because one was leaking. The brakes dont seem right tho. I tested them to see if they would lock and only the rears locked up, not the front. (i was only going about 20 mph) Also when Im going slow I can hear the front pads scraping on the "turned rotors". And when I apply my brakes its like I can hear a whinning/vacuum sounding noise coming from the front brakes, its slows down as the car slows......Whats up with all this?
wishmister@yahoo.com
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Performance Resource Chip
Flowmaster Muffler
Throttle Body Coolant bypass
TPIS air Foil
K&N's
Gutted air box
Accel 8.0 plug wires
Moroso Super Coil
Blue Streak Cap and Rotor
AC Delco Rapidfire plugs
Mobil 1 15/50 Synthetic motor oil
Mobil 1 synthetic Trans fluid.
Old Nov 5, 2000 | 10:56 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
when you changed the back cylinders,,,did you bleed the brake lines ?? you might have air in them
New website home
**The ****** at Anzwers.org deleted all of my files w/o notice**
- 4 out of 5 people think the 5th is an idiot
Old Nov 6, 2000 | 09:04 AM
tf0r1's Avatar
Car: 92 RS 25th Aniv. V8
Engine: 350 L05 TBI
Transmission: 700R4 Raptor
sounds to me like you need to bleed them, and have you had the rotors cut???
I hope this helps
--G
92 RS 25th Aniv.
350 Goodwrench (NEW LO5)
700R4 Raptor: high performance intermediate billet servo,Mega Valve,13 vane high performance pump,1800 heavy-duty stall converter and a 29 element heavy-duty forward input sprag
Old Nov 6, 2000 | 06:04 PM
Yes I bleed the brakes as a matter of fact I removed all the old fluid out of the master cylinder and refilled it with synthetic fluid and then used one of those "one man bleeders" to suck all the old fluid out of the lines until the new fluid came thru. Yes I had the rotors turned.
Do new brakes usually make noise until the seat? Let me know.
1987 White IROC-Z
305 TPI LB9
700-R4 auto tranny
87,000 miles
Very Clean car
Flowmaster Muffler
TPIS air Foil
K&N's
Gutted air box
Moroso Super Coil
Old Nov 7, 2000 | 09:11 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Have you checked the wheel bearing play after you re-packed 'em? Other than that, I think you're right, it's probably the front pads breaking in.
When you say you removed the old fluid from the master cylinder- you left the ports covered in old fluid, right? I'm just wondering if you introduced some kind of air into the m/c body.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
1Aauto
Sponsored Vendors
Nov 23, 2015 02:17 PM
z28_AJ
Aug 27, 2015 08:59 PM
kyleb24
Aug 15, 2015 08:24 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
