Weld on or bolt on relocation brackets for my lca?
Old Oct 31, 2000 | 09:07 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Which are better? And who makes the best ones? Are the bolt on ones a direct bolt on? or do I have to drill? thanks
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Nov 1, 2000 | 06:48 PM
ede's Avatar
ede
never heard of bolt ons. i'd go with weld ons. give steve spohn a call or e mail. he makes great products.
-=ICON MOTORSPORTS=-
Old Nov 2, 2000 | 07:31 AM
sharon's Avatar
Car: 83 Sport Coupe
Engine: 383ci
Transmission: turbo350
I saw an ad for bolt-ons in a magazine. It may have been GMHTP, but I can't quite remember.
Check Out My Website
Sharons Virtual Junkyard
Old Nov 2, 2000 | 07:51 AM
SteveSpohn's Avatar
There are at least two companies I know of that make bolt on relocation brackets. What they do is use the LCA bolt like all the brackets do, and then they run a third point that bolts fast to the lower shock bolt.
I could easily build them, but I won't. We played around with it, and do not feel it is at all safe. Plus, you get alot of twist in the LCA bracket under acceleration load because they only tie one side of the bracket on the front side (shock bolt).
The lower shock mount is designed to take a vertical load (the shock). It is not designed to take an extreme horizontal load.
Our verdict was that it was not the optimum in safety and/or performance. We feel the only right, and safe way to install relocation brackets is to weld them on.
I am not putting down anyone's product, just sharing my thoughts after we conducted R&D on this.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Nov 2, 2000 | 10:29 AM
89ProchargedROC's Avatar
Steve
Damn! The suspension God has spoken.
Old Nov 2, 2000 | 05:03 PM
BLACK Z's Avatar
Car: 86 Z28
Do these brackets improve cornering? My car has been lowered.
Old Nov 8, 2000 | 08:47 PM
BLACK Z's Avatar
Car: 86 Z28
btt
Terrell351
Jun 13, 2021 01:13 PM
Genopsyde
Nov 11, 2015 10:46 PM
Thirdgen89GTA
Aug 20, 2015 03:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
