Front end popping......need help
Old Nov 3, 2000 | 01:14 PM
Troy 85Z's Avatar
Car: 85 Z
Engine: Edelbrock Injected 350
Axle/Gears: 3:42 LS1 Posi
There is this popping sound coming from my front end when I turn the wheels. I replaced the ball joints, tie rods, and idler arm. That didn't fix it. It sounds to be coming from the steering box but it's hard to tell. Does anybody know what the problem could be? Do I need a new steering box? Thanks
Old Nov 7, 2000 | 01:42 AM
Black Beauty's Avatar
Car: 90 Camaro RS
Engine: 305 TBI
i got the same problem...let me know if you figure it out
Rick
90 Camaro RS 305 TBI
400 on the way!!
TH700-R4 with Trans-Go shift kit
MacEwen Motorsports White Gauge Overlays
K&N Filter Charger (wooohooo)
GTS Headlight and Taillight covers
5% Limo Tint all around
Classic White Chevy Bowtie sticker on rear window
Man if my camaro were a rice-rocket all those mods would give me what...easily 50-60 hp!!!
Old Nov 8, 2000 | 09:20 AM
86IROCZ's Avatar
I had the same problem. Whenever I would stop or turn at low speeds, there would be a popping noise. I replaced ball joints and bushing and it didn't go away.
It turned out to be a loose brace. There is a triangle shaped brace connecting the front crossmember to the fram of the car. It didn't feel loose when I wiggled it, but I got about two turns on each of the bolts holding it on. (There is a brace on each side of the car). Those noises went away (but I still have a thousand others to take care of)
Old Nov 13, 2000 | 08:52 PM
Chuck91Z28Conv's Avatar
I had the infamous popping noise in my 91 Z when I bought it (used). 5 shops could not figure it out. Finally, a mechanic started tightening every bolt in the front end he could find. He said they were tight but 'not to specs'. After he tightened all the bolts, the popping went away and has not returned in 2 years.
Tighten ALL the bolts you can find up under there.
Chuck Rini
Perry Hall MD
91 Z28 305TPI Convertible Black
92 RS 305TBI T-Top White
Old Nov 13, 2000 | 10:36 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
fantastic research here gentlemen!
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
