one side sits lower than the other?
Old Apr 6, 2010 | 11:10 AM
nickhil2003's Avatar
Car: 1982 trans am
Transmission: 4 speed
Axle/Gears: 3.08
Okay so when i bought my car in September last year the rear passenger side was sitting lower than the rest of the car. None of the sway bar links were hooked up, so i did that and it helped a little, but it still sags. I think the rear coil spring might be causing it but I'm not really sure.
Old Apr 6, 2010 | 11:25 AM
Stephen's Avatar
Car: 87 GTA
Re: one side sits lower than the other?
Springs can be worn out, broken, not installed correctly......All causing a car to not sit correctly.
It'll take you getting under the car & looking at everything, to find out.
Old Apr 6, 2010 | 03:21 PM
Car: 1982 trans am
Axle/Gears: 3.08
ive been under the car, and everything seems to look okay nothing broken or anything, atleast not that i can see.
Old Apr 6, 2010 | 04:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Drop the axle a bit, without ripping the rubber brake line, and yank the springs. I wouldn't be surprised to learn that the pass side was broken.
Farfetched, but I suppose someone could have replaced the driver's side with a taller spring. If the pass side isn't broken, compare it with the driver's side.
JamesC
Old Apr 6, 2010 | 06:31 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
its actually very common from what i've seen for the rear passengerside to be lower than the driverside. All the subframe and chassis measurements seen to be dead-nuts on, but maybe the spring perchs on that side ended up getting installed a little higher every so often on the assembly line.
I should look into that a little, my 92 is level in the rear, my 86 is not. maybe i can get a measurement.
Old Apr 7, 2010 | 12:13 AM
Car: 1982 trans am
Axle/Gears: 3.08
the strange thing is, i have the exact same problem on my 1981 camaro. Could it happen if a car sat with a flat tire for a couple of years, i dont know if this would wear the spring out or not.
Old Apr 17, 2010 | 02:16 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Got the same thing going on with my 88 and everything looks fine. You guys ever find out what's causing yours to do this?
Old Apr 17, 2010 | 02:23 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
yep i have also heard that alot of cars do this including my 87
Old Apr 17, 2010 | 08:14 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
My 86 IROC sits at about a half inch to a full inch lower on the passenger side... Maybe it's made this way so that when the driver sits in the car it equals out? I measured from the fender lip to the top of the tire that's where i got my measurements..
Old Apr 18, 2010 | 04:38 PM
Boogie123's Avatar
Car: 88 Camaro
Transmission: Th350
Axle/Gears: 3.73's
Don't think so because a friend that was riding behind me pointed it out. I'd never noticed before.
customblackbird
Aug 15, 2021 10:16 PM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Street Lethal
Aug 14, 2015 08:25 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
