Turns normal left, easy right
Old Nov 21, 2000 | 09:20 AM
R.O.B.'s Avatar
My TA for some reason now seems to turn perfectly normal to the left, but when I turn to the right, its like a Cadallac, REEL easy. What could this be? I don't recall hitting any major bumps or pot-holes.
Rob
'86 TA 305 TPI
Old Nov 21, 2000 | 07:59 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Bad steering box.
Old Nov 21, 2000 | 08:48 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
yup,it's the PS case alright, don't buy it from the dealer! I found a liftime warrantied PS case at auto zone for $189,three 16mm bolts hold it onto the D-side frame rail(one is under the angle brace)you need clean drain pan,a pitman arm puller,16mm or 15mm,11mm,10mm socket,extensions, swivel bit.I used a large flathead to pry the shaft away,it should telescope between the couplers,just oil it a little.you need at least a foot hight lift in the front to acces
Old Nov 21, 2000 | 10:21 PM
R.O.B.'s Avatar
DAMN! I was afraid of that.
Thanks guys.
Rob
'86 TA 305 TPI
Old Nov 21, 2000 | 10:53 PM
Engine: 2.2
it's not hard to do ,just time consuming,I heard bleeding the pump properly is a little tricky though.
Old Nov 22, 2000 | 12:19 AM
ColinOpseth's Avatar
Car: 1987 Camaro IROC-Z
Engine: 305TPI
it's a piece of cake job.. while you're at it do a good job of checking out the rest of your suspension.. if your power steering box is toasted i can only imagine what your tie rods look like!!!
don't forget, new PS belt while you're at it, they're a BITCH to get on right, do the job right bro
Fronzizzle
Mar 18, 2019 08:29 PM
apo_bailon15
Mar 28, 2016 05:20 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Fronzizzle
Aug 9, 2015 01:15 PM
