its cheap to just replace Polyurethane Panhard Bar Bushings Poly Bushings ?
Old Apr 10, 2010 | 11:51 AM
Thirdgen6.6l's Avatar
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
Do you guy think its cheaper just to replace the poly bushing with stock part ? how hard is to replace the bushings on rear low control arm, pan bar, rear sway bar ? or replace it with all new brm or spohn part ? my goal is making 350whp. Thanks
Old Apr 10, 2010 | 12:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: its cheap to just replace Polyurethane Panhard Bar Bushings Poly Bushings ?
its cheaper, but doesnt really prove much, the stock parts are pretty flimsy.
personally i wouldn't waste time changing bushings on those parts, or boxing them ect. I would just pick new parts from whomever you prefeer, BMR, UMI, spohn, global west, hotpart, ect ect ect.
poly busings bind, unless the car is just for cruising and going straight, i would go for at least one end of each piece as a rod end or rubber.
Old Apr 10, 2010 | 12:39 PM
Yea car is for going stray line , you right I think imma change out with new part .
Old Apr 12, 2010 | 09:12 AM
UMI Sales's Avatar
Hello
Like mentioned above the factory arms and pan hard bar are made just from stamped metal. Even if you did have replacement bushings the control arms will still flex and bind the bushings and eventually you will be in the same position you are in now. I would suggest to go with a grease able bushing and as long as they are properly greased they will last for years to come. Below is a link to show you what all UMI Performance has to offer as far a factory replacement.
http://www.umiperformance.com/catalo...roducts_id=140
If you have any other questions feel free to ask.
Brad
Old Apr 12, 2010 | 09:44 AM
Hi, that wat I got on my 4 gen z28, I think imma go with adjustable this time.
Old Apr 13, 2010 | 09:09 AM
TimeTraveller's Avatar
Car: 92 TA convertible
Engine: 5.0 TPI
Transmission: 5 speed
Axle/Gears: 3.08 posi
I hope this doesn't come off as being annoying, but for what reason(s) would boxing the stock pieces be a waste of time? From previous experience, I know that boxing chassis rails and other channel-shaped parts is an excellent way to increase torsional & linear strength in them. Are there other problems with these parts (LCA's, Panhard bars) that exclude this technique?
Thanks!
TT
Old Apr 16, 2010 | 05:18 PM
Engine: 5.0 TPI
Thanks!
TT
Does anyone have an answer to the question?
TT
1992rs/ss
Jan 31, 2025 05:10 PM
customblackbird
Aug 15, 2021 10:16 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
NBrehm
Aug 5, 2015 07:57 PM
