changing/bleeding brake fluid ,quick question-
Old Nov 22, 2000 | 08:46 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
how do I properly change my brake fluid?
will bleeding them dry cause damage the master cylynder/calipers?
Old Nov 22, 2000 | 09:03 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
Here's what I do. I first suck out almost all of the old brake fluid from the plastic reservior, clean the inside of the reservior with a towel (or something that won't leave behind fuzz), and pour in new brake fluid. Then I bleed the brakes starting from the right rear, then left rear, right front, and finally left front. I always get a good solid pedal if I'm careful enough to not let air bubbles up inside the bleeder screws. It's definitely not a good thing to bleed the master cylinder dry since then you'll have to "bench bleed" it, which usually involves removing it from the car and all sorts of other stuff I've seen on TV and haven't had to do.
I've used the Ford HD brake fluid since its boiling point is 550 degrees and works great for road-racing. Speed bleeders make the job much easier, and you can even bleed them by yourself and not need a helper to push down on the brake pedal. Just keep an eye on the brake fluid level in the reservior and pump the brakes until clean fluid comes out of each corner...
Greg Westphal
'87 IROC 305TPI/A4
Old Nov 22, 2000 | 09:41 PM
Engine: 2.2
thanks greg
LittleFranks
Sep 17, 2015 12:22 PM
kyleb24
Aug 15, 2015 08:24 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
Leggman1
Aug 6, 2015 04:15 AM
