full discs on a 84?
Old Nov 25, 2000 | 12:36 AM
DaveZ24's Avatar
full discs on a 84?
I am wanting to upgrade the brakes on my 84 V6 before I move on to the engine. I know the 15th anniversary model had four wheel discs, will these bolt on to my car or am I going to need a new rear end? I am looking for a bolt-on application with little to no modifying or fabricating.
One Man...One Search...One Goal...MORE POWER!!!!
Just a Nitro guy living in a Nitro world!!!!!
Old Nov 25, 2000 | 07:01 AM
ede's Avatar
ede
just a WAG, but i'd say you need the whole rear. i have a 10 bolt out of a 85 z28, so i know the rear are out there someplace to be found.
-=ICON MOTORSPORTS=-
1st & 3rd
Old Nov 25, 2000 | 08:10 AM
84IROC's Avatar
I just completed this swap into my '84(check Sig). The entire rear axle carrier will have to be swapped in from a rear disc car because the flanges on the end of the axle tubes are completely different.
I spent less than $350 for every thing out of the wrecking yard!
This is what I replaced,
*Complete rear axle housing, for reasons mentioned above/calipers and rotors and brake lines(I got lucky and mine came with 3:42 gears and posi diff).
*Emergency brake cable from caliper all the way to the splitter plus the extra bracket that bolts to your original on the bottom of the car.
*Rear brake line from proportioning valve back to the single line coming from the rear axle. )Because it will enter the new prop. valve at a different angle)
*proportioning valve/master cylinder
(the fittings are different plus the routing/bends are changed slightly)
(also I went with the '89 model valve because it fit the front brake line fittings)
(I have '92 valve but could not use it because the thread pitch in it were different from front brake line fittings)
*If you do not get the prop. valve from a rear disc car you may have to install an adjustable valve in the rear brake line to cut down on the pressure.
'89-'92 PBR rear disc are the brakes of choice(light weight and fewer problems then the earlier units)
If you have any questions feel free to e-mail me.
'84Z28/'92 305TPI
'92 complete rear suspension/PBR disc/Posi/3:42
Light weight 34.5mm stabilizer bar in front
23mm sta. bar in rear
rear lowered 1" by cutting 1 1/4 coils of '84Z28 springs
comp cam, flowmaster
TB coolantbypass/shutoff valve to heater core
MAT relocated
Ram-Air(home-made) gutted air-box
IROC ground effects/wheels GY245/50's
700R4 superior shift kit/ corvette servo(excellent shift kit BTW) Rebuilt engine and transplanted it myself. Love this engine!
LOW performance people should drive low performance vehicles!
[This message has been edited by 84IROC (edited November 25, 2000).]
Old Nov 25, 2000 | 09:06 PM
DaveZ24's Avatar
Thanks 84IROC, I thought that might be what had to be done but wasn't sure. I am assuming that any 3rd gen rear end will bolt in. As far as brake lines I am going to upgrade all the lines to stainless steel, or flexible stainless lines where I can. So all I need is the axle.
You don't happen to work for Bell-Textron do you?
Old Nov 26, 2000 | 11:24 AM
84IROC's Avatar
Yes, any 3rd gen axle will swap in and no I do not work for BELL.
drptop70ss
Oct 4, 2015 09:44 PM
Stryker412
Sep 20, 2015 06:59 PM
banksGTA
Sep 13, 2015 11:56 AM
64Chief
Sep 12, 2015 08:05 AM
ericjon262
Sep 11, 2015 06:07 PM
