Rear drum problem
Old Nov 22, 2000 | 08:13 PM
nicksL98's Avatar
Rear drum problem
Ok.. i put all brand new brakes on my car..the rears have NEW cyls, shoes and hardware..BUT.. it is snowing here in ohio and i found another problem. All 3 camaros i have owned do/did NOT hold the rear brakes!! I push my foot as hard as i can and the fronts work great, the rears just spin on the snow/ice...whats the problem?! The master cyl is good, so i have eliminated that already. Any ideas out there?? Four wheel stoppin would help greatly
Old Nov 23, 2000 | 02:35 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Make sure they are adjusted properly. With the rear raise off the ground, spin the wheel. There should be some drag, if not, turn the star adjuster wheel until they do drag. Personally, i like a high pedal, so i adjust the rears so they really drag hard. It wont stay that way for long and will have to be readjusted often, but i dont mind.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 23, 2000 | 02:26 PM
evilho7810's Avatar
My car is the same way. No matter what I do it wont stop.
Old Nov 27, 2000 | 01:06 PM
jrr's Avatar
jrr
Sometimes the teeth on the star wheel are worn or damaged and the self-adjuster arm won't rotate the wheel to make the shoes take up the gap.
I've had to file and reshape the adjuster arm so it will bite into the star wheel and turn it like it's supposed to.
jaridjohn
Jul 8, 2024 03:49 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
AkDrifted
Aug 17, 2015 07:45 PM
