Steering wheel shaking when braking`
Old Dec 22, 2000 | 02:24 PM
irocbsa's Avatar
When I am braking and coming to a stop the steering wheel will shake back and forth for about 3 seconds at around 30 mph. What is going on? It feels like the damn front end is about to fall out.
bsa
Old Dec 22, 2000 | 02:25 PM
irocbsa's Avatar
forgot my sig.
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat, Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Dec 22, 2000 | 02:57 PM
ede's Avatar
ede
your rotors are warped, machine or replace them
ICON Motorsports
1st & 3rd
Old Dec 22, 2000 | 05:22 PM
CrazyRob75's Avatar
warped rotors are felt through the steering column and brake pedal. it won't cause the steering wheel to go left to right. If, when braking, it feels like a wheel just bent and the car feels like it's bouncing up and down violently, you probably have a bad crack in the frame behind the steering box causing big time flexing when braking. I had this problem on my camaro.....didn't do it all the time but when it did.....HoLY**** was it time to hang on! check out the post "....popping and klunking in the frt. end". I go into a little more detail about the cracks and how to repair them. Welding it up fixed my problem!
Old Dec 22, 2000 | 05:32 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I agree..also I would look everything over in the front suspension.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Dec 22, 2000 | 05:36 PM
irocbsa's Avatar
greeeeeaaaaaaatttt. well it sounds like its time to dump another ****load of cash into the money pit..........thanks for the help. I'll get that taken care of soon.
bsa
Old Dec 22, 2000 | 09:13 PM
GregWestphal's Avatar
Car: '87 Camaro IROC-Z
Engine: 385 HSR
Axle/Gears: 3.42 posi
irocbsa, what's your best 1/4-mile et/mph with those mods? Which cam (specs if you have them) and rocker arms (ratio, model) did you get? Are the TF heads the 23-degree or the Twisted Wedge model? Thanks! I just bought the TF 23-degree heads (with the CNC'd combustion chambers) and CompCams ProMagnum 1.6 roller rockers, and just got the LT4 HOT cam the other day, as well as bunch of other parts, for my 350/355 engine buildup.
Greg Westphal
'87 IROC 305TPI/A4
Old Dec 23, 2000 | 12:33 AM
Tom Keliher's Avatar
It's your tie-rod ends. They are worn out, and have free-play in them.
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Dec 23, 2000 | 05:11 AM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
When I first bought my ride, the front pads needed to be replaced. After I did, I had the same problem. I replaced the front right rotor and it stopped.
Also, my entire steering linkage was recently replaced before I got the car.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Dec 23, 2000 | 09:47 AM
Violent wheel shaking like irocbsa described is not from rotor warpage. That is more like a pulsation. The violent shaking is from worn out steering components.
FORMULA 350 TK
Old Dec 23, 2000 | 11:50 AM
irocbsa's Avatar
Thanks Tom, I'll check that out. I'm pretty sure it is not a crack in the frame. I'm getting no popping or klunking at low speed when turning.
Greg: My best e.t. with the 2.73 rear was 13.6 @ 100.1. I just put in the 3.42 rear and it really made the car come alive. The motor produces a whole bunch of torque and the 2.73 was really keeping it out of its power band. I'm expecting around 13.3 next time I go to the 1/4. The specs on the Comp Cam are as follows:
Duration: (@.05)
Int. Exh.
206 210
Lift:
Int. Exh.
451 480
Lobe Sep. Angle = 112
The cam will pull to about 6100 but the power tapers off at about 5600. The stock tune port has a lot to do with this I think.
As for rockers I went with Comp ProMagnum 1.6. The heads are of the Twisted Wedge variety.
[This message has been edited by irocbsa (edited December 23, 2000).]
Old Dec 24, 2000 | 02:00 AM
JPrevost's Avatar
Car: 91 Red Sled
I too think it's warped rotors. I know when front stearing parts get warn out they don't just shake when braking, but more so ALL the time at all speeds. My friends car has warped front rotors and it sounds to be exactly what you're experiencing. Good luck.
, Jon (91 RS too many mods to list)
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
overdriv
Aug 20, 2015 03:52 PM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
