Changing struts/shocks.. can someone give me a step by step?
Old Dec 25, 2000 | 08:17 PM
Jeremy_84_F41's Avatar
Car: 1991 Formula L98
Axle/Gears: 3.73:1
I just want to make sure I do this right.. I'm pretty sure I just put the car up on stands for the front, and support the control arm with the jack.. and then I guess it'll be pretty self explanatory from there, just 3 bolts I think.. right?
And I have no idea for the rear.. I've never looked up under there. Where to the tops of the shocks mount in the rear? Do I need to remove the interior trunk panels, or... ?
Thanks in advance
-Jeremy
Old Dec 25, 2000 | 09:47 PM
sven86berlinetta's Avatar
They are incredibly easy! I got the directions for mine with the shocks, did it step by step, and it worked out perfectly.
The rear is easy. The top bolt is in back of the rear seats, the carpet folds up. There is one bolt on top, one bolt on bottom.
Fronts are also easy. If you don't get directions with the shocks/struts, get a haynes/chiltons manual or something (if you don't have one already).
Trust me, you have nothing to worry about.
Luke
94 Saturn SL (1.9L)
86 Camaro Berlinetta (5.0L) *TPI 350 In Progress*
Berlinetta Board Mod @3rdgen.org
Non-Tech Mod @LG4 Performance Team
Old Dec 26, 2000 | 02:52 AM
Bort62's Avatar
The Carpet Folds up like a Fox! I had to Take Half My Freakin Interior Out To Get To Them
Other than That, Easy
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Livin' the Stereotype
Old Dec 26, 2000 | 09:16 AM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
I believe its in the tech board on this site.
Later,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 @ 94.77mph
GTAman
Mar 15, 2019 11:40 AM
maroe624
Apr 16, 2017 08:29 AM
mdtoren
Aug 23, 2015 12:52 PM
crazynights
Aug 21, 2015 06:53 AM
mdtoren
Aug 16, 2015 05:45 PM
