Strut Tower Brace, any good?
Old Dec 24, 2000 | 12:14 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
I have many chassis upgrades and know what works well and what doesn't. I'm wondering if anyone has a strut tower brace and has good things to say about them. Can you actually feel a difference from this piece? I have a Z28 and carb with no clearance between the hood and the air filter. Does someone make one for my application?
1986 CAMARO Z28 -> 151,000 original miles, 43,000 on 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear and 0 miles, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, Spohn LCA's, Spohn adjustable panhard rod, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Homemade ram air, B&M shifter, Extreme Energy 230/236 cam.
Old Dec 24, 2000 | 01:58 PM
camarodarrell's Avatar
I just installed an edelbrock stb the other day and it made the steering feel a lot more direct. Definately a mod you can feel. I think edelbrock might make one for your car. Check carparts.com, they have coupons here http://www.camaroz28.com/carparts/
[This message has been edited by h-town z (edited December 24, 2000).]
Old Dec 24, 2000 | 08:51 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
I agree... do it! You will be kicking yourself why didnt I do this sooner! I recently installed one it helped alot on my car. I will be preaching this mod till every thirdgen has one. The towers flex bad on these cars,it gets worse with high mileage.
Get a 3 point brace if you can find one.
Black 90 IROC, L98, A4, 323 gear. SuperRamed 406 in the works!
Old Dec 26, 2000 | 09:41 AM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
JDMZ28,
I have heard it is sort of tight for a carb car with dual snorkel and AC bracket. Someone said you have to modify the AC bracket. Check out www.edelbrock.com and you might be able to get a picture of it there. Spohn performance is coming out with one in the spring. I have a picture of edelbrock stb on a 91 firebird but don't know how to post pictures to this board.
Have fun,
Craig
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649@94.77mph
Old Dec 26, 2000 | 08:17 PM
1989CamaroRs's Avatar
i rember reading post awhile back that someone said they had heard of windshields cracking under extreme turning when you have a strut tower brace installed. Is this possible?
Edelbrock TES Headers, High Flow Cat, Edelbrock Catback, SSM Subframe Connectors
Old Dec 27, 2000 | 01:20 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Wouldn't a STB prevent that from happening?
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
Wouldn't a STB prevent that from happening? I've never heard of that but I would like to know also.
Old Dec 27, 2000 | 12:07 PM
I've only heard of a windshield cracking with a 3 pt stb on a 4th gen because of the steep windshield. I don't think this would happen on a 3rd gen.
Old Dec 27, 2000 | 12:08 PM
zee28's Avatar
Car: 86 iroc
never heard the windshield thing.I would think it would be oppisite.anyway I think edelbrock and retailers need to drop the carb listing for thier brace until they make it really fit.its not a true bolt on piece for a carb car with ac.
~mike~
1 superclean 86IROC-Z
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
NBrehm
Aug 5, 2015 07:57 PM
