4th Gen brakes on 3rd Gen
I am in the process of building a 86 fbird as a road racer and what I want to know is can 4th gen brakes be applied to a 3rd gen. I know that the rear axle from the 4thgen will bolt up, therefor allowing the usage of the brakes, but what about the fronts.
If they can be used, then would it make more sense to use the larger brakes of the 1998-present f-body? Will these fit?
Thanks for all the help you guys have given me in the process of my build-up (some through the FAQS, some by direct emails).
Any thoughts?
Any thoughts?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Nope, the 4th gen fronts are not the same and wont bolt up. You'll need thirdgen 1LE brakes, or aftermarket brakes like Baer or Wilwood.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
