problem installing passenger LCA
Old Dec 31, 2000 | 01:55 AM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
ok..drivers side came off with a little bit of muscle, went on simple. Kool that ones done. The bolts on passenger side were easier then the drivers to un-bolt. Now after i got the old LCA off i put the new one up...the back end i bolted on then went to bolt the front end of the LCA on...wait there likes 2" from the LCA bracket to the end of the LCA..wtf? is it just the body is sitting lower on that side or something? what gives? What should i do to bolt that end in?
89 Firebird
2.8 V6 w/ t5 tranny (383 tpi t56 w/ ati 12/01)
Flowmaster 80 series, 3" Intermediate, SS Tips, Random Tech Cat, Msd Coil, MSD 6a, Accel 8.8 wires, Cold Air Intake w/ K&N, Lakewood LCA's, Brushed aluminum Hood pins ETC...
My Site:
www.geocities.com/firebird89white
" I'd rather run last in a full out race, than to NOT run at all ".
Old Dec 31, 2000 | 09:47 AM
ede's Avatar
ede
i believe the rear has shifted on you. try a jack, pry bar, or a pull chain to move it forward to where you can get the bolts to go in.
ICON Motorsports
1st & 3rd
Old Dec 31, 2000 | 10:13 PM
dnovotny's Avatar
Yeah, my rear shifted quite a bit as well. At least you did one at a time. Crowbar is what I used to line up the bolts and bolt hole. Just make sure you don't bend anything important on the chassis.
Dave '91 T/A
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
TheExaminer
Aug 25, 2015 07:34 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
NBrehm
Aug 5, 2015 07:57 PM
