Torque Arm Mount Install
Old Apr 26, 2010 | 06:56 AM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
How big a job is it to replace the torque arm mount? any help would be great. THANKS (84 trans am auto)
Old Apr 26, 2010 | 07:50 AM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Re: Torque Arm Mount Install
Are you going to change the complete mount? You're probally going to have to drop the tranny i belive to get enough clearance to get the bolts out.
You can take the side piece off, by the 14 mm screw and the 15mm bolt at the top. I've done it. If you're lucky, you can take the other 15mm bolts loose, and take the crossmember or the tranny mount loose, and push the trans over enough to get the other 2 bolts loose. I highly doubt it'll work, but its worth a try.
Best bet is to just drop the crossmember, and see where that gets you. If not, take it all the way out.
I'm not sure if the rubber piece will just come out, if it will, just take the half off, then move the arm out theway, and replace it and put it back...
Hope this helps.
Old Apr 26, 2010 | 08:24 AM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
No, i just want to change the bushing. Not the whole mounting bracket. THANKS
Old Apr 26, 2010 | 09:29 AM
Engine: 355 chev
I've never taken the bushing loose, but i'm assuming it pushes in to the bracket. Just get under the car, take the drivers side half of the mount loose. Theres a 14mm screw and the 15mm bolt that goes through. When you get it out, slightly push down on the mount, and push it towards the back of the car, then tilt it down to the ground and the front should come out of the slot.
Old Apr 26, 2010 | 11:31 AM
brutalform's Avatar
Are you going with a poly bushing? You are going to have to get the mounting bracket off. IIRC, you will need to drill the little dimples off of each half of the bracket, to get the old bushing out.
Old Apr 26, 2010 | 01:43 PM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
yes a poly and i already have the revits out with a die grinder but i can't get the clam shell bracket together? THANKS
Old Apr 26, 2010 | 01:45 PM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
yes a poly and i got the rivets off with a die grinder but i can't get the clam shell together? THANKS
Old Apr 27, 2010 | 09:33 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
are you sure you have the correct mount? I had a similar problem. I had the wrong mount. They made 2 different ones, depends on which way the lips on the torque arm are pointed.
Old Apr 27, 2010 | 09:52 AM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
Not sure, I might have the wrong mount? Should the clamshell close fine with the right mount? THANKS
Old Apr 27, 2010 | 10:13 AM
3rdgenmaro's Avatar
Car: 88 IROC
crawl underneath and look at it.
Mine closes easy. slide the tab at the bottom into the slot, push together and put the bolt in up top. Take the bushing off the torque arm and try to put it in. It will go only one way. once you get it in, look and see if the lips face the same way or not as the ones in the torque arm.
Old Apr 27, 2010 | 05:18 PM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
Yes i have the wrong bushing. Is ther other one that different? it almost fits?
Old Apr 27, 2010 | 06:37 PM
3rdgenmaro's Avatar
Car: 88 IROC
the other one will fit perfectly.
Dont feel bad. I done the exact same thing.
Old Apr 27, 2010 | 06:57 PM
bljweeks's Avatar
Car: 84 trans am
Engine: 305 carb
I hope so this as been a head ach... Thanks for your replies
Old Apr 27, 2010 | 09:54 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
I had the same problem...I bought mine from summit and they only listed one energy poly bushing for the 700r4. I just bought a longer bolt and with a crow bar shut it and tightened it up...it hasn't squeaked yet....
Old Apr 27, 2010 | 10:08 PM
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
i just trimmed mine with a real sharp utility knife, put it in a vise, i took the bracket off so i knew how much to trim. I bought a edelbrock torque arm and had the same problem.
Old Apr 28, 2010 | 07:32 AM
3rdgenmaro's Avatar
Car: 88 IROC
when did you look at summit? Ive seen two listed for awhile.
ENS-3-1111 for lips facing away from the driveshaft
and
ENS-3-1112 for lips facing towards the driveshaft
G code at the end for Black, R for Red
and if you have an 82-83, ENS-3-1110
Old Jul 12, 2014 | 12:41 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Any issue(s) with the poly bushing not being affixed to the mount like the original mount... I assume just grind off and remove the old mount and just fit the new poly mount in place or roll?
Old Jul 20, 2014 | 10:32 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
hat's all I did. The mount is two pieces, just grind out and clean/prep the mount. I sprayed the mount with Bed Liner for protection and used an ES mount. Pretty simple.
Old Jul 20, 2014 | 11:59 AM
Engine: LB9 | LS1
Nice job!
Vintageracer
Jan 10, 2020 05:33 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
IROCZ1989
Jan 24, 2016 03:55 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
