Will GTA rims fit my car?
Old Jan 4, 2001 | 07:53 PM
84 T/A's Avatar
Will 16" GTA rims fit on an '84 Trans Am? Will they rub in turns? If they fit, what size tires are recommended? Thanks.....
  • 1984 Trans Am 305 H.O., M5, Posi 3.73, Q-Jet 4bbl. 4-wheel Disk Brakes
    160 Degree thermostat, Mobil 1 Synthetic fluids.
Old Jan 6, 2001 | 03:18 PM
Craig84Z's Avatar
Car: 1984 Camaro Z28
Engine: Blueprint 383
I think they will fit okay w/o rubbing. You should be able to use 245/50 tires. I know I can go from a late model camaro 16" whl to my 84 Camaro Z28. I am assuming the GTA rims have the same offset as the Iroc type whls. Remember you have the front rims w/ zero offset and the rears are 16mm offset(if same as Iroc whls).
84 Z28 305HO, 5spd, 220,000 miles, Edelbrock intake, Hedman headers, low restriction exh(w/cat), K&N air filter. Best 1/4 so far 14.649 at 94.77mph
Old Jan 6, 2001 | 07:46 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
They should fit with no problems.
I have 4 front GTA rims on my 86 T/A.
The fronts rub when you turn really sharp.
I have 245/50/16's. I will be switching to 255/50/16 in the future to get rid of some wheel well gap.
Zepher
'86 Pontiac Trans Am WS6, LG4 305, 5 Speed, CF DF Clutch,
Edelbrock 1406 Carb, Edelbrock Performer RPM 7101 Intake Manifold.
Edelbrock Open Element Air Cleaner: Flowmaster Exhaust, 160* Thermostat,
Grant GT Steering Wheel, MSD HEI Coil, Taylor 8mm Wires, Leather 96 Camaro SS Seats,
Alpine CD+Changer,Alpine V12 Amps, Premier TS-1040C Subs, Polk Audio highs/mids.
Best ET: 14.94@91.67
High Speed Run: 157mph
WS6 Trans Am
Old Jan 7, 2001 | 12:10 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Thirdgen rims are completely interchangeable. You can go from 15" to 16" just by swapping. Make you sure get the fronts and rears lined up correctly, like was said above.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Jan 8, 2001 | 12:26 AM
88 GTA Notchback's Avatar
Hell.. I have a GTA and the front wheels rub!! I have a shiny spot on each wheel well.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT
88 Mustang GT
94? Impala (real close)
97 Dodge Neon
86 Corvette
And more Civic's then I can count. Why do they even bother?
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
87iroctheo
Wheels and Tires
Aug 29, 2015 09:44 PM
Exxon Limited
Aug 9, 2015 08:13 PM
