Stock spring length?
Old Jan 12, 2001 | 07:51 PM
NickS's Avatar
I'm looking at putting a set of 975lbs straight rate springs that are 12" long on the front of my '92 Z28. Does anyone know what the length of a set of stock Z28 springs is? My car currently has cut stock springs in the front, so I can't use them for comparison.
The reason I'm asking is that I need to know if these springs will drop the front, and if so, by how much. That will give me an idea as to how much negative camber I'll gain (or loose) by going to these springs.
- Nick
'92 Z28 CMC #45 (The road race car)
'01 Silverado 1500 (Tow vehicle)
Old Jan 12, 2001 | 08:04 PM
CamaroMike's Avatar
975LBS!!!!!!!!!!! OOOOOOOOOKKKKKKKKKKK!!!!
I run 707lb/in front 90 Iroc springs and they are plenty stiff. Why not weld up the struts and eliminate the springs? It will ride the same either way. J/K
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Jan 12, 2001 | 10:29 PM
NickS's Avatar
heh - well, its not exactly a street car, so the high rate springs are more there to keep the nose from diving too hard under braking. .
Soooo... Anyone measure 'em out?
- Nick
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Aug 26, 2015 03:32 PM
1988iroc350tpi
Aug 14, 2015 07:52 PM
