E-brake
Old Jan 7, 2001 | 02:43 PM
dudelovett's Avatar
E-brake
I'm in the process of making sure that everything in/on my car is perfect and one of the things I still have to do is tighten my e-brake. How would I go about doing this on my car?
1991 Firebird Formula
305 TPI
Auto
K&N Filter
Grant GT Steering Wheel
5% Rear tint
Pontiac Windshield Decal
No real mods yet!
Former owner of an 88 2.8 Firebird....RIP
Old Jan 7, 2001 | 02:44 PM
dudelovett's Avatar
Oh yeah, I have drum rears
Old Jan 10, 2001 | 02:33 AM
Adam89F's Avatar
Under the car, 1/2 way down in the middle.
Above the track bar and exhaust, there is an adjuster.
One wire runs to it from the parking brake handle in the interior; two wires exit it and travel to each rear wheel.
This is where you do your adjusting.
The Hayne's manual shows you how to do it.
I can't describe it because it's been awhile.
West Coast Performance
1989 Formula 305 TBI
Old Jan 10, 2001 | 06:12 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
First make sure your drums are adjusted. You can crank on the "equalizer" like mentioned above, but it won't do squat if the shoes are too far from the drum.
Take the drum off, and at the bottom, there will be a little "star wheel". You will need to turn it away from the arm. If you have to lift the arm, you are going the wrong way. Keep turning until you can put the drum on and when you turn the drum, there is a slight drag felt. Then do the other side. If this does not correct the e-brake, then adjust the equalizer underneath.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Jan 10, 2001 | 06:56 PM
dudelovett's Avatar
Thanks guys!
After adjusting my drums, everything was okay!
Old Jan 13, 2001 | 12:52 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
FYI, there is no provision for adjusting the e-brake at the equalizer saddle on 90+ cars. I have a 90 RS and a 88 Iroc. The Iroc has the threaded rod at the equalizer to allow adjustment of the older (pre 89) disc brakes. There is no such adjustment on my 90. Only can adjust the drum brakes individually with the star wheel as described.
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
jawzforlife1
Apr 25, 2002 03:36 PM
The Dirty Bird!
Apr 1, 2002 02:36 PM
stuart69427
Feb 22, 2002 08:38 PM
88transam5.0
Dec 19, 2001 06:58 PM
