*alignment specs posted* alignment / drivin issues...need help
Old May 5, 2010 | 07:10 PM
BlueZee28's Avatar
Engine: Cammed 6.0L LSX
My car pulls to the left pretty hard going down the road, not a slight drift, it pulls. So I had a friend do an alignment today and he said before it was pretty out of whack, but he got it straightened out but it's still pulling about as hard as it was before. He suggested a possible bad tire, like the belts slipped inside and it needs to be replaced on that side of the car.
My concern is, when I was doing my engine swap, I had the front frame rails on jack stands but one of the jacks slipped. My jack stands have the top piece that's shaped like a fork, with two fingers (makes the shape of a "Y" instead of a flat surface). The jack that slipped, the frame just dropped down into the groove on the jack stand instead of being on top of the two fingers. The other side stayed on the fingers of the jack. So this made the front of the car sag down on the left side a few inches. I didn't really think much of it, but do you think this could have bent the unibody? I'm like really freaked out now....The rear of the car was on ramps if that makes any difference. I'm going to swap the front and rear wheels this weekend and see if it still pulls, I hope it does which would mean one of my front tires is bad....what do you think?
Old May 5, 2010 | 07:27 PM
1983Zsled's Avatar
Car: 1983 Z28
Engine: 355 SBC Vortec heads
Axle/Gears: 3.42 Posi
Re: alignment / drivin issues...need help
I'd doubt that that much deflection is going to make a difference. These cars have had the frames bend so much that while on the hoist you cant open and close the doors....
You may want to check your brakes out to make sure you aren't dragging a brake caliper or shoe. I have never heard of a bad tire making a car pull hard, without the vibration and shake, in which case you'd know but who knows maybe that is the case.
Seems more likely to be a dragging caliper, or brake issue.
Old May 10, 2010 | 07:09 PM
BlueZee28's Avatar
I don't think it's the brakes, I don't hear any noise or anything coming from them, there's no un-even pad wear, and the brakes are smooth when depressing the pedal. I haven't had a chance to swap the tires yet, I will get around to that this week though and see what I find. I hope you're right about the frame, I don't know what I will do it the frame is bent from something so stupid
Old May 11, 2010 | 03:55 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
Try feeling the wheel after a longish run, if your left wheels are hot (particulary the front) that would signify brake bind and be the reason for the pull.
You would not necessarily hear it but it is one of the more common reasons for the pull. Also what does it do under hard braking?
Old May 11, 2010 | 09:26 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
just throwing out a little concern...if it is a bad tire, you should probably find time, asap, to swap them and then replace, if needed. it will only get worse (potentially coming apart). It looks like you've got a really nice car, now!
Old May 11, 2010 | 10:36 AM
Guest
Guest
Posts: n/a
Two simple questions-
1) Did the car pull hard to the left before it feel of the jackstand?
2) When your "friend' aligned the car for you, what tools and gauges did he use?
In other words, take it and have it professionally aligned on an alignment rack by someone who knows how to check camber, caster and toe settings as well as rear axle thrust angle.
Old May 11, 2010 | 03:12 PM
BlueZee28's Avatar
I want to say it pulled before the swap, but its been so long I can't remember. I'm almost positive it pulled though. And my friend works at a Plaza Tire which is a chain of shops, he did the alignment at work on a rack.
Old May 11, 2010 | 11:30 PM
Guest
Guest
Posts: n/a
Can you post the final printout specs then so I can help diagnos the problem?
Old May 13, 2010 | 09:38 PM
BlueZee28's Avatar
I forgot to mention that the car is lowered about an inch and a half with the Hotchkis springs, and the front end has the Spohn tubular k-member, but I did not buy the tubular a-arms yet. I'm not sure if not having the a-arms will make a difference, it shouldn't by theory if the alignment specs are right, correct? Anyways, I tried to get my scanner to work but it's not working for some reason.
Here's the specs:
Before measurements:
Left Front Camber -0.2*
Left Front Caster 3.5*
Left Front Toe 0.09*
Right Front Camber 0.3*
Right Front Caster 5.5*
Right Front Toe 0.00*
Total Toe 0.08*
Steer Ahead 0.04*
Thrust Angle 0.14*
After Measurements:
Left Front Camber 0.3*
Left Front Toe 0.00*
Right Front Camber 0.1*
Right Front Toe 0.02*
Total Toe 0.02*
Steer Ahead -0.01*
Thrust Angle 0.13*
Old May 13, 2010 | 11:17 PM
Guest
Guest
Posts: n/a
Re: *alignment specs posted* alignment / drivin issues...need help
Even a circle track car turning only lefts does not have 2* caster spread. That is major yanking your car left.
Put your caster to 4.0 left and 4.5 right
Old May 14, 2010 | 02:27 PM
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Definitely try another alignment shop before anything else. For what it's worth - my GTA did that with a bad tire after it had set up for a long while.
Old May 14, 2010 | 02:35 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Agreed. The most I put on a car is .5 degree difference. Also (and this goes for anyone suspecting a bad front tire) if you think a tire is making your car pull just rotate the fronts side to side and see if the car pulls the other way.
Old May 14, 2010 | 07:47 PM
BlueZee28's Avatar
Will do, this is the second shop to do an alignment on the car since December. I'm gonna take it back to my friend's shop and have him adjust the caster to where the difference is within 0.5*. If that doesn't work then I will go rotate the tires, but from the sounds of it you guys know what you're talking about.
Old May 15, 2010 | 12:13 AM
pestrada38's Avatar
Car: 1990 FORMULA WS6 T-TOPS
Transmission: BORG-WARNER T5
Axle/Gears: BORG-WARNER 3.42
The same happened to mine. I got the alignment and then when i hit a bump or the road was uneven it would pull to the left. I took it back to the shop and they said nothing was wrong. I decided to buy new tires and problem solved.
Old May 15, 2010 | 04:34 AM
Guest
Guest
Posts: n/a
Trust me its not your tires, its you caster split.
Old May 15, 2010 | 08:33 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Old May 19, 2010 | 06:08 PM
BlueZee28's Avatar
Vetruck....you sir, are the man! I took the car up to my friend's shop again today and had him narrow the gap between the caster settings, now the left is at 3.7 and right is at 4.1, and the thing feels like a brand new car. I drove down the highway for a good 1/2 without even touching the wheel. It's so weird to drive it and not have to be constantly holding the wheel to the right, I haven't had a good alignment on the car in probably 2 1/2 years.
Old May 19, 2010 | 08:35 PM
That's good to hear, I can't wait to get mine aligned tomorrow after installing all of the adjustable peices!
Old Feb 16, 2011 | 11:11 PM
grego93536's Avatar
Car: 91 rs3.1, 87 iroc 305 6 speed
I have been a tech fof 35 yrs. I always use a spread of; 5 min more negative camber, and qt min more positive caster on the rt. This prevents a drift to the cfown of the road sithout /reatinb a drift.
Old Feb 16, 2011 | 11:16 PM
grego93536's Avatar
Sorry about the numbers (big fingers, small keys). They should be: 5 min more negative camber and 15 min of positive caster
Old Feb 17, 2011 | 09:11 AM
do you mean -5 degrees of camber? and i don't get the 15 min of positive caster.. if you mean 15 degrees then that is impossible i think ?
Old Feb 17, 2011 | 01:46 PM
Guest
Guest
Posts: n/a
I think they are doing this stuff on some of these new high tech machines in figures like latitude and longitude type readings. I think it is refered to as clock like settings for a pimp[oint in accuracy when you think of a clocks 3 hands- refer to the settings as the hour hand position. If you had it on 3 oclock exactly (90*) or the hand just a slight bit past it at 3:02:47sec would be something like 90.0147- just an example and not an exact calculation)
Old Feb 17, 2011 | 02:18 PM
I had thought that's could have been what he meant.. It looks like that could be more precise than the way I see it in degrees.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
