are they worth it...LCAs and PHB.
Old Feb 16, 2011 | 09:02 PM
Gibson's Avatar
Car: 1989 Camaro IROC-Z
Engine: LB9
Axle/Gears: 3.08 G80
so i have a chance to get one hell of a deal on hotchkis LCAs and PHB. its all new stuff too. my question is, is it worth it? i have the f41 suspention in my car now, would it be a worthwhile upgrade to run those LCAs and PHB?
Old Feb 16, 2011 | 10:40 PM
White'89's Avatar
Car: '89 GTA
Engine: 5.7L LS1
Axle/Gears: 9 bolt 3.27
Re: are they worth it...LCAs and PHB.
Cardboard cutouts would be an improvement over the stock stuff. I just replaced both on my car. You could twist the panhard bar by hand and almost the same with the LCA's. So if you have a deal in front of you don't pass it up.
Old Feb 16, 2011 | 11:32 PM
Gibson's Avatar
Engine: LB9
the deal got even sweeter after i talked to the guy. im tradin a set of 17" wheels and tires (6 bolt wheels of my old mazda truck) for the parts listed above plus 150. ill be able to get eiter a good set of springs or a set of gta wheels now.
Old Feb 16, 2011 | 11:43 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
deffinately do it. especially for the LCA's. the phb is nice too
Old Feb 17, 2011 | 07:04 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
would recommend as well. the stock bushings by this time are probably pretty beat (unless they've been replaced already), new parts will definitely make a difference. is the PHB adjustable? good idea to go that route if you're lowering the car
Old Feb 17, 2011 | 07:25 AM
Convoy25's Avatar
Car: 95 Z85 S10, 99 Formula
Engine: 4.3 CPI , LS1
Transmission: NV3500, T56
Axle/Gears: 3.08, 3.42
yes definetly. when i got my SS it had crappy tires + stock suspension which = a bad wheel hop. i replaced the LCAs and PHB and the wheel hop was gone 80% of the time.
Old Feb 17, 2011 | 08:36 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
try some LCA relocation brackets. might add an addl 20% to that number
Old Feb 17, 2011 | 02:30 PM
Convoy25's Avatar
the firestones helped with that
i may after i get some other things first
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
skinny z
Oct 5, 2015 06:23 PM
bjpotter
Oct 4, 2015 07:48 PM
gord327
Oct 3, 2015 01:25 PM
6998poncho
Sep 25, 2015 02:56 PM
