Cutting Springs?????
Old Jan 22, 2001 | 06:26 PM
NJ SPEEDER's Avatar
can anyone suggest a good tech article on how to properly cut down stock rear springs? are there any probs associated with cutting springs?
my problem is that i have taken so much weight out of my car for drag racing that the back of the car is about 2.5" higher than stock. any other way i can lower it on the cheap with out messing up my launching ability?
thanks
tim
91 Camaro RS-LO3,Auto.
14.301 @ 94.39mph
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
Old Jan 24, 2001 | 06:40 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
The Camaro Performance Handbook has a section in the back about trimming the springs written by Herb Adams. The guy who helped design the 3rd gen suspension when he worked for GM. Basically he cuts em with a torch, bends the end back to a stock appearing configuration and lets them air cool vice dousing them in water like some say to do.
Rob P
89RSconvtZZ4TPI
Edelbrock Hi-Flow Intake
SLP Dual Cold Air Intake
1 5/8" Headers
Semi-Siamesed Runners
MSD6AL/relocated MAT/ AdjFPR/IROC frnt@rear swaybar/wonderbar/steeringbox/alum drvshaft/ Alston SFC/3:23posi disc rear/MAC LCA/H.Adams Panhard Rod/KYB struts/ shocks/
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jan 24, 2001 | 07:04 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Umm,, putting a freshly cut hot spring into a bucket of cold water would be a slightly bad idea.
My Firebird
Part Breakdown Diagrams
Old Jan 24, 2001 | 09:19 PM
CamaroMike's Avatar
Use a high speed cutting wheel to cut off (in small 1/4 coil steps) the tangential end. That would be the end at the top or the one that only touches in one place.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
gta892000
Aug 11, 2019 11:16 AM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
FormulasOnly
Sep 6, 2015 10:42 AM
